Famous Racing Quotes: Got one?
#102
Re: Famous Racing Quotes: Got one?
You can lead the whole race, but if you aren't there at the finish it doesn't matter.
A women can leave you and take your car, the car will never leave you and take your women.
#104
sorry if these are repeats, but I aint reading 5 pages.
"Racing makes heroin addiction seem like a vague longing for something salty" peter egan
"If you dont chew Big Red, then *** you" ricky bobby
#105
"autocross is for fast drivers, drag racing is for fast cars" quoted from someone
" im faster then fast, im quicker then quick, im lightning!" from the movie cars
#106
Why isn't this old thread more than a 100pages???
Here's my 2cents:
My speed is rivalied only by the lighting bolts of heaven! - The Cannonball Run ( the shiek)
Here's my 2cents:
#108
#110
Re: (ghettoracer)
but then there are always amazing exceptions. the 911 gt3 RS will have a 3.8L NA putting out 450hp, but in that case its about rpm........the gt3 redlines at 8500...the RS might be higher. the S2000 was great when it came out but was even better with the bigger engine, because they kept the same hp but redline dropped 1000rpm which means they increased torque........torque is good.
#111
Re: (ek_freek)
"make sure you fill the car with fuel BEFORE you start the race"
"always hit the john before a race"
#113
HT White Ops
Peter Egan describing what each tool is for:
HAMMER: Originally used as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools that transform human energy into a crooked, unpredictable motion; the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...."
HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender.
EIGHT-FOOT-LONG 2X4: Used for levering a motorcycle off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating oil buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you have forgotten to disconnect.
1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: Its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced by a power plant 200 miles away and transforms it into compressed air that travels by hose to a pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Springfield, and rounds them off.
#114
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH!!!!!! LOLZ
#117
I just read all 5 pages, created a new account, resurected a 3+ year old thread, and I don't even own a Honda anymore, just to post this quote y'all missed:
"IF IN DOUBT, FLAT OUT!" - the great Colin McRae (RIP)
Sidenote: He's also credited with
"Straights are for fast cars, corners are for fast drivers."
great quotes so far though!
#118
But there is one more, not directly related to racing
"Your here for a good time, not a long time" Colin McRae
#119
#120
Can't find the reference but I will edit when I find my book...
"You only have enough power when you can lay two black stripes from corner to corner"
DG-FNR
06-12-2017 01:35 AM
SpeedFactoryRacing
02-10-2012 10:40 AM
davidluko
32
05-25-2005 05:25 AM
AFTERZERO
03-15-2005 09:14 AM
