Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
engine weights
Old Mar 19, 2004 | 09:24 AM
xtrac1's Avatar
rookn00b
Default engine weights
Does anyone know what Honda engines ( B, H, K series) weigh? Trying to figure out what is ideal for H1 class.
Old Mar 19, 2004 | 10:59 AM
chad's Avatar
Moderator
Default Re: engine weights (xtrac1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtrac1 &raquo;</TD></TR><TR><TD CLASS="quote">
engine weights do NOT matter for h1 since there is a minumum weight for the car anyways!
Old Mar 19, 2004 | 11:42 AM
Crack Monkey's Avatar
Default Re: engine weights (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">
engine weights do NOT matter for h1 since there is a minumum weight for the car anyways!</TD></TR></TABLE>
Well, they do, just not as much. All the extra weight over the front wheels will alter handling a bit.
Old Mar 19, 2004 | 11:53 AM
xtrac1's Avatar
rookn00b
Default Re: engine weights (Crack Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">
Well, they do, just not as much. All the extra weight over the front wheels will alter handling a bit.</TD></TR></TABLE>
Exactly!
Old Mar 19, 2004 | 11:55 AM
Can't give you exact weights, but generally D &lt; B &lt; K. Remember that H1 cars are weighed according to engine type, see the rules for the exact amounts.
Old Mar 19, 2004 | 11:56 AM
.RJ's Avatar
.RJ
hondachallenge.com --&gt; rulebook
Old Mar 19, 2004 | 12:07 PM
chad's Avatar
Moderator
Exactly!</TD></TR></TABLE>
and that is easily over come with correct suspension setup!!! spring rates etc.....
wow...those who think it will make a difference.....BS....drove everything but a kseries powered hatch so far....just drive it!
Old Mar 19, 2004 | 12:27 PM
MightyMouseTech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">Can't give you exact weights, but generally D &lt; B &lt; K. Remember that H1 cars are weighed according to engine type, see the rules for the exact amounts.</TD></TR></TABLE>
I thought the K series were in fact LIGHTER than the B series.......
Hmm, less weight, more filling......sounds good to me.
And the lighter you make the engine the better the weight distribution and the stiffer the cage you can build for the same base weight..
Old Mar 19, 2004 | 12:31 PM
Default Re: engine weights (MightyMouseTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">
And the lighter you make the engine the better the weight distribution and the stiffer the cage you can build for the same base weight..</TD></TR></TABLE>
You're right, I mistyped.
D &lt; K &lt; B
And I'm not disagreeing with Chad - all engines can be setup to handle well, but they will require different setups.
sr20honda801
May 2, 2006 05:28 PM
mafia
Acura TSX
10
Jul 9, 2005 04:42 AM
ACrite3404
Apr 8, 2005 11:51 PM
k24a4kid
37
Nov 23, 2004 05:53 PM
gamakichi77
Oct 5, 2004 08:29 AM
