EG/DC Rear toe out opinions
I have been playing with rear toe a little to try and find the best balance. I am currently a total of 1/4 toe out in the rear and was wanting to work my way back to 0 to see how things felt. Prior to this weekends toe fix (driver rear had slipped 100% toe in at the last event) I had eyeballed it on the adjustment slot to match both sides. Stringing the car this weekend, it was almost 1/2 toe out in the rear and was all over the place when on the brakes. I got it on the string and quicktrick tapes (both sides) 1/8th toe out, 1/4 total. The car still rotates nice and it does pretty good under braking albeit still a little squirrely hard on the brakes. What have you guys found to be optimal for rear toe? I know every car is a little different but what is your preference? What toe settings typically show faster lap times for tight tracks, fast tracks etc..?
Thanks for the input in advance!
Re: EG/DC Rear toe out opinions
1/8" toe in required 90* more steering wheel input at Oak Tree compared to 1/8" out, for me. Toe out is a little "dancy" under braking as you've seen; and while I think it most likely faster, for an endurance race & multiple drivers I want it a little more comfortable. Next time I head back out I'm going to run 0* rear toe, I think that will be a happy balance.
*edit* I think rear downforce would compliment rear toe out nicely. With the rear toe out, even coming up the uphill esses at VIR was a little dicey.
well its semi complicated... depends on the track, your bushings, and what your suspension compression takes to you with your toe.
I'm on fully sphericals and run 1/16 rear toe at VIR, 1/8 rear toe out at Summit. We keep the "drag" down on the tires there because of the two long straights. after measuring my toe with the suspension compressed... its giving me about 1/8th compressed, slightly more with unknown side load. I would try to run 0 toe but I cant get the PCI rear toe links to go in that far... so I'm going to build my own.
Thanks for the info on OakTree, that is great feedback.
1/8" rear toe out on each side is quite a bit. I would back it down to 1/8" total so the car will be stable under hard braking. You can always get the car to rotate around the front end by braking harder later in the braking zone, as long as you have a little bit of rear toe out.
keep in mind without a good trailing arm bushing (basically spherical), it will toe out under bump. I had this at turn 1 at mid o...not fun when the right rear suddenly toes out mid corner...
the dancing rear under braking is more solved with the front end and a touch of downforce that any actual rear end setting imho/experience.
im at zero rear toe and starting to work on getting the rear tires to "work more".
I'm at a 1/16th toe out and have PCI sphericals. Doesn't feel that loose on high-speed turns, or under breaking. No aero other than OE GSR rear wing.
You know, I think switching to sphericals will also help my issue. I was seeing a ridiculous amount of rear "squirm" under hard braking before with more than a 1/4 total, now being at 1/4 known, its not nearly as bad but is still there. I think that If I can get it in s bit more to an 1/8th overall it should be good to go with hardened rubber in the rear. With the spherical RTAs and LCAs and minimal deflection I should feel pretty stable between 1/8th-1/4th track dependent.
What could be deflecting under compression if its all spherical? Or is it that it rotates out at the compressed suspension geometry?
Another thought.. any thoughts about leaving the camber adjuster rubber on the rear? Or will it continue to gain negative camber under compression even with sphericals with dw suspension?
What kind of front end work are you talking about? Do you mean toe in at the front? Or stiffer springs??
It might be worth mentioning what spring rates/bar rates people are working with. Stiffer fronts won't see as much rear loading, therefore theoretically the toe out would make less of a difference as the tires will be experiencing less slip angle.
not sure what your question is about the front?
im 1000f/600r, 32mm hollow rear bar 0.120 wall, no front bar. i just dropped the rear rate from 700, need to dial in the bump stops/packers before nationals...but it will still toe out under bump and scare me
I just meant your note here... "the dancing rear under braking is more solved with the front end" Just curious what you mean by solving it via the front end.
he's talking about going from a rubber front compliance bushing to a spherical bushing. It reduces the toe change under braking up front due to rubber deflection, somehow making the rear end more stable.
Other things that help:
*rear wing
*softer rear rebound setting on your shocks
*rear wing
ah gotcha now, dilbones nailed it. rear end shimmy can actually be the front end dancing so its important to not chase the wrong end of the car...been there done that.
but fr. the car is a whole picture. it's similar to making a good meal. can't just make good taters and expect the fam to be like damn what a fire meal--gotta have good chicken and green beans and shxt too.
(front and rear matter)
Ill let you guys know how much the sphericals help, I have a set of compliance, RTA, FLCA on the way =-) I decided to run the last event at 1/8 out rear total and with the RLCA and front UCA/upper spherical bushings installed and the squirm was still there but it was much more manageable. The rotation was very good set up like this, rear 24mm bar is set to soft and dampers were set in the middle f/r.
