Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
DRY CELL Mounting rule changes
Old Jan 20, 2006 | 08:32 AM
Grumpy's Avatar
New User
Default DRY CELL Mounting rule changes
18.8 Battery
The battery shall be securely fastened down to the car. No Bungee cords or rubber
cords may be used to function as the sole hold down mechanism. An electrically nonconductive material must cover the positive battery terminal. Any battery located inside the driver’s compartment shall be fully covered and firmly secured to the chassis in a marine type battery case. True dry cell batteries may be mounted without a surrounding case. Note- there is a difference between “dry cells” and “gel cells.” Gel cells still need
to be mounted in a case.
Old Jan 20, 2006 | 08:35 AM
splitime's Avatar
Default Re: DRY CELL Mounting rule changes (Grumpy)
"Marine Type Case"
Would an "army" ammo box suffice?
Old Jan 20, 2006 | 08:39 AM
thawley's Avatar
What type are Hawker/Dynabat batteries?
Old Jan 20, 2006 | 08:43 AM
splitime's Avatar
Default Re: DRY CELL Mounting rule changes (thawley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote">What type are Hawker/Dynabat batteries?</TD></TR></TABLE>
Also curious as to the type of battery the Braille Batteries are.
Old Jan 20, 2006 | 08:59 AM
Grumpy's Avatar
New User
Default Re: DRY CELL Mounting rule changes (splitime)
Case must be non-conductive.
Old Jan 20, 2006 | 09:01 AM
Grumpy's Avatar
New User
Each battery has as Material Safety Data Sheet. Should tell all. Try the website of the manufacturer.
Old Jan 20, 2006 | 09:04 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grumpy &raquo;</TD></TR><TR><TD CLASS="quote">Case must be non-conductive.</TD></TR></TABLE>
Rats... I guess its good mine is just for a HPDE car. I'll be securely covering all terminals also.
dk127
Oct 6, 2010 03:47 PM
Turbo_Mike
Jun 25, 2009 03:30 PM
esponet
Sep 26, 2004 11:25 PM
oz#227
Dec 2, 2003 01:34 AM
Spikey
Aug 22, 2002 08:03 PM
