Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
DOT 5 brake fluid...
Old 04-02-2002, 12:04 PM
I forgot more about hondas then you will ever know....
Rodney's Avatar
Location: hop,skip, and a jump from the city,, new friggin york, USA
Default DOT 5 brake fluid...
tried the search, but to no avail..
dot 5 silicone brake fluid anyone? i'm overdue for a fluid flush, and was thinking about dot 5 silicone. i know it has a higher boiling point, but what about it's resistance to water absorbtion? do you have to bleed it more often? i need some real world experience here. i have spoke to a variety of people, and everyone has a wildlt different opinion? anyone care to take a stab at it? thanks.
Old 04-02-2002, 12:55 PM
New User
Grumpy's Avatar
Default Re: DOT 5 brake fluid... (rodney)
Most raceers don't use it. There must be a reason.
Mine was that I could never bleed out all of the microscopic bubbles in the fluid and always had a soft pedal.
Grumpy
Old 04-02-2002, 12:56 PM
typer_801's Avatar
DOT 5 = no, no (has silicone, will ruin your whole system) unless your system is designed and already has DOT 5 in it.
DOT 5.1 will work well, but expensive.
Why not just used a good DOT 3/4 fluid. ATE Super Blue/Type 200 are more than adequate for most cars and is $10 a liter.
Here's a nice link with comparisons of BP's between many fluids. It comes to the same conclusion. Choice is your's however...
http://www57.pair.com/lane/bfluid.htm
Old 04-02-2002, 01:12 PM
New User
nsxtcjr's Avatar
Default Re: DOT 5 brake fluid... (typer_801)
Another bad thing about DOT 5 (silicone based brake fluid) is that you can't mix DOT 5 fluid with non-silicone based brake fluid, like DOT 3 or DOT 4 or DOT 5.1.
No, it isn't.
Better yet, why not get a fluid that has even higher boiling points than ATE, like Motul RBF 600? It costs about the same as ATE.
Here are the dry and wet boiling points for many of the most popular brake fluids:
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3 MINIMUM
DRY:446F -- WET:311F --- DOT4 MINIMUM
DRY:500F -- WET:356F --- DOT5 MINIMUM
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
ARRANGED BY WET BOILING POINT:
Old 04-02-2002, 02:01 PM
typer_801's Avatar
Default Re: DOT 5 brake fluid... (nsxtcjr)
HUH?!? Unless my math skills have seriously deteriorated, Motul RBF is more than twice what ATE costs.
Motul RBF shows up at $12.99 per 500ml (1/2 liter) at Racer Parts Wholesale, while ATE SuperBlue can be had at OG Racing and many other places for $10/liter or around $5/500ml. It's much more expensive if you ask me!
"Why not just used a good DOT 3/4 fluid. ATE Super Blue/Type 200 are more than adequate for most cars and is $10 a liter."
Old 04-02-2002, 02:06 PM
Wrong-Way Wang
Warren's Avatar
I prefer Motul. If you call around to local bike shops, you can pick it up for $10 each. I dunno why it's more expensive online. Kind of odd.
Yeah, it's twice as much as ATE, but I have had 2 problems with ATE. First, is that sometimes it eats seals, especially in Audis (odd since Audi uses an ATE master cylinder), and second is that ATE has a squishy pedal by the end of one day.
Warren
Old 04-02-2002, 02:22 PM
4doorH22's Avatar
Default Re: DOT 5 brake fluid... (Warren)
Anyone know if ATE eats seals on Hondas? I've been using ATE for quite some time with zero problems. Pedal is only begining to get mushy now after 5 months and 3 HPDE weekends since the last flush. Then again I don't drive like Warren... but my car does weigh more and has smaller brakes...
Old 04-02-2002, 02:23 PM
Crazydave's Avatar
Just run motul and be done with it
Old 04-02-2002, 02:40 PM
typer_801's Avatar
Default Re: DOT 5 brake fluid... (4doorH22)
No problems ever here <knock on wood> Been using ATE since the early 90's in a variety of cars (4 VW's and the Type R).
For a street driven car that sees occasional light track or autocross action ATE is more than adequate. For a more dedicated race setup, I'd probably go with a higher performance fluid like the Motul, but it's not necessary for me.
Old 04-02-2002, 03:20 PM
New User
nsxtcjr's Avatar
You might be right - although you can get Motul for less elsewhere, say $10 for a half liter. That means every time you do a full flush of your fluid, it will cost you $10 more ($20 vs $10). Maybe you flush once a year, maybe twice a year. So for an extra $10, maybe $20 a year, you get boilover protection that's 57 degrees F higher. That's a HUGE difference in the boiling point - and well worth spending a few bucks more a year.
I have yet to understand why people will try to skimp out on brake fluid for a few bucks, and risk fade and boilover at the track. You probably get more value for those few bucks by spending them on brake fluid than on any other mod on your car.
Corksil
06-28-2011 02:24 PM
2k1 SSM GSR
03-23-2005 10:02 AM
kommon_sense
01-04-2005 11:46 AM
SilverDc2
06-06-2004 08:54 PM
turbotypeR@SPEC
12-11-2002 03:42 PM
Quick Reply: DOT 5 brake fluid...
