CRX oversteering bad...what is it?
1988 CRX HF
Things affecting handling for information:
- battery relocated to back
- no heat, no a/c, gutted rear
- B18C5 (generally considered pretty light)
- FSTB, rollbar
- Azenis 205/50/15 RT-615's on Falken Hanabi 15x7's all around, equal tire pressures at 29 psi (low i know)
- GC 400f/600r springs
- Koni Yellows
- ST 22mm rear sway bar on outer most hole, stock CRX HF front sway bar
- Replaced rear trailing arm bushings
I started off with the rear shocks full stiff, front full soft: oversteered
Then I put the rear halfway soft, front stillfull soft: oversteered
Front and rear at full soft, getting desperate here: oversteered
Not this is nuts, rear full soft, front halfway stiff: oversteered
What is wrong? I have VIR HPDE next weekend!
I'm going to try 33 psi up front, 32 psi in the rear sometime soon, maybe that'll help.
Modified by GI8U2racing at 11:52 AM 3/25/2007
- FSTB, rollbar
- Koni Yellows
Of course not, I am usually in partial throttle, which should make it understeer if anything. I have done some turns without throttle, and it oversteers then too. Should I try disconnecting the rear sway bar?
Re: (GI8U2racing)
A guy on another board had a similar problem, with the rear stepping out uncontrollably, mid corner. for him, it was his left front upper balljoint.
Location: living too close to Karl, everythings busted, nc
Re: (GI8U2racing)
Jon, what were the specs on your alignment? with that set up, car should be quite neutral to oversteery(word?) I would stiffen the front shocks, and maybe raise the air pressure in the front.
Where were you able to drive it to find it oversteered, auto-x?
Re: (o-man)
I would like to know your alignment specs as well. Were you at a trackday or autox? Was it high speed or low speed corners?
With that setup, the car should push and not have any oversteer on throttle depending on the alignment.
Re: (prkiller)
I figured it out...the rear right wheel bearing was not seated on all way, allowing me to move the wheel around in any direction. I fixed that, then put all the tires to 32 psi, it understeered like a *****
So now I have it 90 degrees off full soft in the front, 90 degrees off full stiff in the rear, and it's perfect.
I did it in an open parking lot at about 30 mph doing a continuous circle like a skidpad.
Got a new problem though, my gas tank builds pressure and leaks gas out the fill...I guess I'll start a new thread
Re: (GI8U2racing)
88 CRX's had different rear compensator arm mounting locations vs the 89-91, hence the 88's are known for being quite a bit more twitchy in the rear.
I had a similar issue with my 88 CRX Si, that thing would just snap oversteer if I wasn't careful! Your spring rates also might have something to do with it? I don't know too much about older hondas in terms of spring rates but I thought most people ran slightly higher front rates then rear. I know the newer hondas (DC5/EP3,etc) they run higher rates in the rear.
Anyways good luck figuring out what it is.
Re: (GI8U2racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GI8U2racing »</TD></TR><TR><TD CLASS="quote">
Got a new problem though, my gas tank builds pressure and leaks gas out the fill...I guess I'll start a new thread </TD></TR></TABLE>
Does the car have a full exhaust? If not make sure you have a turn down. I had a turn down fall off my civic and the same thing happened, the heat caused the fuel to evaporate and pressurized the tank.
black0hatch
14
08-11-2008 08:51 AM
court76wi
48
06-28-2007 09:29 PM
