Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Cornerweight tips
Old Aug 16, 2018 | 02:52 AM
Eknapen's Avatar
Default Cornerweight tips
Hi Guys,
im building a track toy, 1st Gen CRX (1986) B16 Turbo, fully gutted, rollcage etc.
I've put it on scales last week with me in it. and a half tank of fuel.
LF: 613.8 LBS RF: 477.4 LBS
LR: 356.4 LBS RR: 305.8 LBS
would you still try to move some static weight in the car or with the Front Rear ratio of 62.2 / 37.8 and a cross Weight of 47.6% just ajust the +10 and -10 lbs Target weights by adjusting the height each individual wheel?
I would end up with the Rear Bite of 70.6 ( 48.7% wedge ).
All tips and feedback is welcome!
Greetings E.
Old Aug 16, 2018 | 08:49 AM
boxedfox's Avatar
Default Re: Cornerweight tips
48.7% Cross is still in the realm of where you'd have a noticeably different handling through left hand turns vs right hand turns. I would try to physically shift some weight back towards the Right Rear corner as well as adjusting the ride heights to see if you can get any closer to 50%. It will have the added benefit of shifting the static weight rearwards too. Shifting 50 or so lbs towards the back of the car makes a huge difference in how the car feels through corners.
You may have to consider ballasting that corner a little bit to make that happen. We had a similar problem with our D16 powered 2nd gen CRX. The solution we came up with was bolting a big heavy car battery back there and using it as backup power for our light boards.
Old Aug 16, 2018 | 09:19 AM
Eknapen's Avatar
thanks for your advice! Ill move the battery to the back and move the spare tire towards the RR. I need to add Some balast any way because i think 1491lbs without me in it Will also make it hard for me to enter Some of the Racing events over here.
Old Aug 16, 2018 | 07:22 PM
iwannarace's Avatar
damn, you're 250? i think you may need to consider some weight reduction! I like how some of the drivers in the old best motoring vids are like 130lbs soaking wet... Where'd you find that cool worksheet?
Old Aug 16, 2018 | 09:46 PM
Eknapen's Avatar
https://robrobinette.com/corner_weight.htm
yes 250 and 6 feet and 7 inches long.
Old Aug 17, 2018 | 06:53 AM
boxedfox's Avatar
Man, 1491lbs without driver. That's insane. That's 600 lbs less than our Endurance Racing 2nd gen CRX Si and almost 1000 lbs less than my sprint race Prelude Si. That must feel really lively on a full size road course.
Old Aug 17, 2018 | 07:16 AM
Eknapen's Avatar
took a lot of blood sweat and tears to get it there.
And i hope so. Have not put it on a track for a long time.
Old Aug 17, 2018 | 07:21 AM
Ericjergs's Avatar
You should really consider some height reduction.
Old Aug 22, 2018 | 06:06 AM
Eknapen's Avatar
Will think about it.
anyone other ideas or tips?
Old Aug 22, 2018 | 07:06 AM
Josh R.'s Avatar
If you have the scales/time play around with the weight placement. You don't necessarily want to move the weight over the wheel(s) or even farther back, as that's just more weight to move and stop moving. For the most part you want the weight as low and close to the center of the wheelbase as possible. Think passenger side floor.
Old Oct 27, 2018 | 02:17 PM
Eknapen's Avatar
what kind of balast are you Guys using / adding to the car to achieve this?
Old Oct 27, 2018 | 03:10 PM
boxedfox's Avatar
Depends on the location and the rulebook you're working with. If you just need to add ballast to the passenger side floor old barbell weights are a popular option. They are easy to handle and you can find them anywhere. Just drill enough mounting holes in them to spread the load and put a backing plate on the other side of the floor so they don't pull through in a crash.
If you want to ballast a specific corner or end of the car and/or the rules prohibit ballasting in the location where you need weight, you have to get a bit more clever. For example, some cars (e.g. Miatas) are notoriously light in the right rear corner. Most club racing rules prohibit you from adding ballast back there but they are perfectly ok with you using huge 1/4" thick steel plate as roll cage feet and sandwiching them from the underside with another 1/4" plate.
Similarly, the rules for many stock-like racing classes (e.g. Improved Touring) allow but do not require the removal of the spare tyre. When Improved Touring was in its heyday, many a Civic driver would improve their weight distribution by putting a full size 15" steel wheel (with the biggest, heaviest tyre they could find) in the back of their car and bolt it to the floor with long class 12.9 bolts.
n-c
Oct 18, 2005 08:30 AM
J28S
14
Sep 25, 2005 08:40 PM
tnord
May 1, 2004 07:55 AM
LX4CYL
Mar 28, 2004 09:20 AM
hondacivic4g
Dec 13, 2003 11:54 PM
