Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Is this camera mount safe for a HPDE?
Old Nov 6, 2002 | 08:48 AM
Holden's Avatar
Default Is this camera mount safe for a HPDE?
This clamps onto the passenger headrest posts:
If you folks say no, I'll leave my expensive video camera home.
TIA.
[Modified by Holden, 12:49 PM 11/6/2002]
Old Nov 6, 2002 | 08:56 AM
smokin rubber's Avatar
Default Re: Is this camera mount safe for a HPDE? (Holden)
I know a few people who have them, but none of them have tested the device's crash worthiness.
Old Nov 6, 2002 | 08:58 AM
Drew M's Avatar
New User
If I were an instructor I wouldn't feel too good about having that thing next to my head . . .
Old Nov 6, 2002 | 09:09 AM
xevanx's Avatar
I love it! That one looks just as crappy as mine! I'm gonna re-do mine before the next auto-x season starts. Clean it up and make it a bit more stable.
Evan
Old Nov 6, 2002 | 09:23 AM
CivicSiRacer's Avatar
Default Re: Is this camera mount safe for a HPDE? (xevanx)
Drew, would it be acceptable with 2-3 straps to the floor or trunk area? Or is the only approved camera mount to a roll bar or cage?
Old Nov 6, 2002 | 01:08 PM
mityVR6's Avatar
Default Re: Is this camera mount safe for a HPDE? (CivicSiRacer)
I have a Hama suction-cup mount for sale if you prefer that style.
-Adam
Old Nov 6, 2002 | 04:33 PM
sptsi00's Avatar
Default Re: Is this camera mount safe for a HPDE? (Drew M)
neither would I....
Old Nov 6, 2002 | 04:44 PM
SJR's Avatar
SJR
Default Re: Is this camera mount safe for a HPDE? (sptsi00)
I've used that same mount last year at Summit Point Jefferson circuit (NASA event, the mount was in the car at tech). The instructor did not care. If I were you, I would ask the instructor about it before you show up for grid, that'll leave you time to take it off if necessary.
I personally feel that the mount is fine, but since there is someone with you in the car, you really should ask them if they feel it is ok.
Old Nov 6, 2002 | 08:23 PM
whitney's Avatar
Default Re: Is this camera mount safe for a HPDE? (SJR)
Bingo
An instructor may choose not to get in a car for any safety concern. If I was your instructor, I would grab the mount and shake it to see how sturdy it is, then sit in the car and flail my helmeted head around to see if it could possibly impact. If it passed those tests AND was held with extra straps, I would climb in.
I am sure that any instructor would prefer it be attached to a "harness bar" between the b-pillars, well behind the head. Might want to look into one of those. Or, just get a 4-point rollbar! It's perfect for mounting a camera AND keeping your head attached to your body!
Old Nov 6, 2002 | 08:39 PM
sackdz's Avatar
Default Re: Is this camera mount safe for a HPDE? (whitney)
I have used the same mount in the past. Even though mine sucked 10x as bad as yours, the video was still decent.
P.S. The twin-tube design I realize now is retarded. It would be much better to just drill through the center of one box tube with the correct sized bit.
Old Nov 6, 2002 | 09:52 PM
WRXRacer111's Avatar
Default Re: Is this camera mount safe for a HPDE? (sackdz)
I've got a similar mount in my car. However, I've found that with this car, the end of the single metal tube is aimed closer to the instructor than I would like it to be. I bent the tube back, the aim it more towards the rear of the car, but I wouldn't ask an instructor to get in the car with the way it is now. I'm not comfortable with it. It worked better in the Integra.
Old Nov 6, 2002 | 10:14 PM
DSC240sx's Avatar
I talked to someone who had one of these at summit point. He taped it, straped it to the back, put extra ties or whatever on it and everything he could to ensure it's safty. The instructor started to get in the car, saw it and said "no"
I guess it just depends on the instructor...
Old Nov 7, 2002 | 06:07 AM
SPiFF's Avatar
I have a similar one from CruzCam but the bar is longer and it connect to both head rest posts with the camera in the middle. Before I had the roll bar, I used it a bunch. Very stable for video. Never tested the crash worthyness of it though.
Old Nov 7, 2002 | 07:27 AM
Driven's Avatar
Yes.
Is this camera mount safe for racing outside of autocross
no.
Old Nov 10, 2002 | 07:26 PM
Nasa_Racers's Avatar
i made something similar but my instructor would not allow it to be in the car...it is b/c of the rare but dangerous crash and it could literally poke a hole through the driver or the passenger...so i understand and wonder how i can tape my sessions (he wouldn't allow the window mount either b/c of the speeds and other risks)
Old Nov 10, 2002 | 07:51 PM
Evan55's Avatar
Ive always wondered about that. Why all this fancy 2 tubes cut in half with bolts holding it blah blah, why not just take 1 box tube and drill the holes in it. So much easier.
Old Nov 10, 2002 | 07:56 PM
Volcom's Avatar
Default Re: Is this camera mount safe for a HPDE? (elgorey)
P.S. The twin-tube design I realize now is retarded. It would be much better to just drill through the center of one box tube with the correct sized bit.Ive always wondered about that. Why all this fancy 2 tubes cut in half with bolts holding it blah blah, why not just take 1 box tube and drill the holes in it. So much easier.
If you did that, how would you get the holes tight enough so there wasn't any free play? Basically, you need the two tubes pinching the headrest mount to create a very tight fit. Drilling two holes wouldn't create that tight fit.
Old Nov 10, 2002 | 09:21 PM
GRM Scott's Avatar
25 Year Member
Default Re: Is this camera mount safe for a HPDE? (Volcom)
I had almost exactly the above pictured with me at first, for several autoXes and lapping days at Nelson Ledges. Now i have an IOport mount on my rollbar, which is better of course....never had to deal with instructor issue, quality was OK.
D had one that used both headrests, a single bar, and some U-bolts to attach to the posts. Worked very nicely, but seats had to be moved in unison
Asahi
Mar 28, 2005 01:36 PM
SpoonMe
16
Aug 26, 2003 08:53 AM
4drRacer
11
Nov 14, 2002 05:55 AM
YodaIsGod
10
Jul 18, 2002 06:43 PM
