Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Bushing HELP!
Old Nov 12, 2007 | 03:48 PM
SkimN's Avatar
Default Bushing HELP!
I posted this in the suspension forum, but figured I'd have a better shot at finding someone who know's they're stuff here.. mods feel free to remove one or the other if this against the rules
This is for a '97 Accord SE. I was wondering if there is supposed to be a spacer between the two metal top hats like the 1st(seperated), mine are the second pic, is there supposed to be a spacer where the arrows point? thanks
Old Nov 14, 2007 | 06:43 AM
SkimN's Avatar
Default Re: Bushing HELP! (SkimN)
bump for any info, thanks
Old Nov 14, 2007 | 06:54 AM
ccarver's Avatar
the spacer is just to line up the two surfaces in parallel. If your swaybar and control arm are parallel with no spacer, that is not an issue. Just make sure you are not over tightening the bolt and killing the bushings. Also make sure the bolt has threads so that you are getting the bushings tight. There should be a slight deformation to the poly when fully tightened.
Hope this helps.
Carver
Old Nov 14, 2007 | 08:29 AM
SkimN's Avatar
Default Re: (ccarver)
thanks very much
Jaydeep
Honda Civic (2001 - 2005)
Feb 18, 2011 07:33 AM
exies
Suspension & Brakes
Feb 9, 2011 06:08 AM
imadigitalgod
Sep 9, 2010 02:54 AM
rawbeanz
Feb 14, 2007 06:15 PM
EGO
Apr 3, 2003 03:18 PM
