Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Brake issues! Please help!!
Old Jan 22, 2002 | 06:32 AM
rambler's Avatar
New User
Default Brake issues! Please help!!
92 Si Hybrid
Equipped with 99Si brakes, GSR Master Cylinder, GSR Booster, GSR Proportioning Valve.
When the car had the stock lines, and stock 99 brake pads it had great pedal feel and initial bite. It almost felt like the car was "overbroke" but I really liked it.
I swapped the lines for Goodridge SS lines (99-00 Si spec), Cabotech Superstreet pads (all 4) and Motul Fluid. I have now lost that pedal feel that I liked so much. To be honest the pedal feel is CRAP.
What could cause this? My initial thought is that the SS lines have a larger volume (cross section) than the stock lines did. But the SS lines are about 2/3 the length of the original lines which is nice because my new shocks don't have the line mounting locations that the stock lines need (really long).
Thoughts? Opinions?
Any and all help is greatly appreciated!!! TIA!
- Nash
Old Jan 22, 2002 | 06:39 AM
r2x's Avatar
r2x
Default Re: Brake issues! Please help!! (rambler)
Sounds like you are getting air in the system somewhere. Make sure you have a good seal where you installed the new lines and be sure the system is well bled to get any air out of there.
Old Jan 22, 2002 | 06:53 AM
Knestis's Avatar
Line cross section or volume won't make any difference. I agree that they need a good bleed. If that doesn't solve the problem, try swapping the OEM pads back in, to limit your variables, and see if it is any different...
Kirk
Old Jan 22, 2002 | 06:59 AM
.RJ's Avatar
.RJ
Default Re: Brake issues! Please help!! (Knestis)
Also, use OEM honda washers on the ends of the lines, crappy washers may/can leak. Try bleeding again - get some speedbleeders
-Ryan
Old Jan 22, 2002 | 07:14 AM
Flux's Avatar
Default Re: Brake issues! Please help!! (Type-RJ)
How long have you had the SS lines installed? I have not experienced it, but I have heard that the pedal will firm up after a few days to a week after installing SS lines.. I don't know why.
Old Jan 22, 2002 | 07:25 AM
rambler's Avatar
New User
Default Re: Brake issues! Please help!! (Flux)
The brakes have been blead 3 times... (I owe my wife for that!!)
The SS lines were installed on my 00' Si for over 6 months then removed... they have been installed on the Hatchback for about 3 weeks.
Off to a Hardware Store to buy a 10mm tubing wrench, to check all of the connections. I may swap the pads back to the OEM's at the same time.
Old Jan 22, 2002 | 07:42 AM
johng's Avatar
I had a similar problem when I switched to ss lines, Hawk's and Motul. I figured I still had air in the lines, so I bled the system every evening for a week. Maybe it went away....or maybe I just got used to it, but everything feels just ducky now. Could it be a pad/rotor/pad material transfer thing? Andie?
[Modified by johng, 9:22 AM 1/22/2002]
Old Jan 22, 2002 | 08:00 AM
Willard's Avatar
Default Re: Brake issues! Please help!! (johng)
Me thinks it is.
Will
Old Jan 22, 2002 | 09:58 AM
madhatter's Avatar
From: boldly scornful of higher mental function, US
Default Re: Brake issues! Please help!! (Willard)
Bleed the lines. There is air in the system. Also, if you did a complete fluid swap, you might have gotten air in the master cylinder, so you need to bleed that as well, and start all over again. Also, make sure that you are not leaking fluid from any of the bleed screws, or from any of the fitting bolts. HTH.
Old Jan 22, 2002 | 10:52 AM
rambler's Avatar
New User
Default Re: Brake issues! Please help!! (madhatter)
Is there a specific proceedure for bleeding the MC??
TIA!
Old Jan 22, 2002 | 11:06 AM
Xian's Avatar
I remember with my CRX that I had to "bench blead" it. You blead the MC while it is out of the car with tubing running from the MC output lines back into the reservoir. You are supposed to do this until no more bubbles. From what I understand it is very difficult/almost impossible to correctly blead a MC once it is mounted in the car...
Old Jan 22, 2002 | 11:07 AM
madhatter's Avatar
Pull it off the car, hook it up to a bench vise, put return lines into the resivoir where the hard lines normally hook up, fill with fluid, take a screwdriver and push the piston in until no more bubbles come out of the return lines. Then hook it back up to the car, bleed the lines again, and keep the fluid level from dropping or you gotta start all over again. A real waste of fluid, but the only way I know of to get air out of the M/C. You can also look it up in a manual under bench bleeding the master cylinder...
Old Jan 22, 2002 | 11:25 AM
1stGenCRXer's Avatar
Default Re: Brake issues! Please help!! (Xian)
A power bleeder will let you do it, but you will use enough fluid to do an entire flush on the brake system.
Old Jan 22, 2002 | 11:43 AM
rambler's Avatar
New User
Default Re: Brake issues! Please help!! (1stGenCRXer)
Any good links to an online site with a Power Bleeder?!?!
Old Jan 22, 2002 | 01:15 PM
https://honda-tech.com/zerothread?id=116499
Already got some links/helpful info in that thread.
Old Jan 22, 2002 | 03:06 PM
Backmarker's Avatar
Hi there,
For reasons that defy physics, the motul fluid has resulted in a softer pedal feel than other fluids such as ATE. Fade resistance is great, you just don't get the rock hard pedal no matter how much you bleed the lines.
Old Jan 22, 2002 | 08:27 PM
civicrr's Avatar
Default Re: Brake issues! Please help!! (ITR_Hybrid)
I agree. Pedal seems a little soft compared to stock. I am using Motul & Porterfield R4-E pads with Goodrich lines.
Old Jan 23, 2002 | 03:52 AM
madhatter's Avatar
Default Re: Brake issues! Please help!! (civicrr)
Bleed the brakes in the correct sequence. Only way to get a good pedal in a Honda, and it works for me every time:
RR,LF,LR,RF.
Give it a shot.
Old Jan 23, 2002 | 05:37 AM
civicrr's Avatar
been there, done that (check that out. told you guys I was old)
Old Jan 23, 2002 | 05:40 AM
rambler's Avatar
New User
Thanks for all the great stuff guys!!
I think I'm going to do the following....
1. Recheck all the fittings (car off have my wife stand on the brakes and inspect for weeping and/or slow leaks) (Note to self... buy wife something nice and buy myself a 10mm tubing wrench)
2. Purchase a power bleeder and ATE fluid (Blue for now so I know I get a good flush). Flush and bleed the entire system in the sequence madhatter listed.
See what happens....
(if that doesn't fix it)
3. Swap pads back to OEM
(still not fixed)
4. Swap lines back to OEM
I think I need to start with the fluid, after doing much research on fluid last evening I read about the older style plastic containers that Motul is supplied in and how it can absorb air over time, the "new" bottle I used had been on my shelf for about a year. (living and learning).
Keep up the good input! I will keep everyone up to date on the progress!
- Nash
Old Jan 25, 2002 | 01:20 PM
killingtime's Avatar
It took me 3 days to get the front and rears swapped in, and 3 weeks to figure out why I didnt have any pedal.
A friendly reminder that the bleed nipple needs to face UP, not down
Demian
Old Jan 27, 2002 | 12:30 PM
rambler's Avatar
New User
Back to the top with an update...
Spent the last 3 hrs working on the issues @ hand.
1. Bought Power Bleeder & ATE Super Blue
2. Borrowed 10mm tubing wrench
3. Bought new banjo bolt washers from Honda.
4. Replaced washers and checked all connections
5. Flushed the system with ATE
6. Reblead the system conventionally (thank you to my wife)
No dice... still mushy
7. Reblead the system wth the power bleeder
8. Changed pads back to OEM
9. Reblead the system
I am sooo frustrated with this right now... I am taking a break and will change the lines back to stock when I feel *in the right mind* again.
Any and all comments and suggestions are welcome!!
- Nash
Shutweld
May 3, 2018 07:13 PM
carsaregood
Dec 16, 2004 10:35 AM
navin
Nov 4, 2003 05:13 PM
Chugger
Feb 27, 2003 03:51 PM
Charles B.
Nov 11, 2001 04:04 PM
