Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
a bit of testing.....the results
Old Jun 19, 2003 | 05:56 PM
carl_aka_carlos's Avatar
Default a bit of testing.....the results
so after initially running into mid-corner push with my new suspension and solving that by raising the car off the bump-stops, I now have a new dilemma....
my car is loose in left hand turns (READ: it *loves* turning left) and tight in right hand turns (READ: when i turn the wheel right my car says 'maybe tomorrow')
the ride height at all 4 corners is within 1/4inch of eachother. none of my sway bar endlinks are bound, I get full travel at each corner
anyone got any idea what could be causing this?
Old Jun 19, 2003 | 06:01 PM
WRXRacer111's Avatar
Default Re: a bit of testing.....the results (carl_aka_carlos)
checked the alignment?
Old Jun 20, 2003 | 06:06 AM
00R101's Avatar
Default Re: a bit of testing.....the results (WRXRacer111)
almost assuredly alignment - is the frame straight? (yes, I know it doesn't really have a frame)
Old Jun 20, 2003 | 06:30 AM
solo-x's Avatar
Default Re: a bit of testing.....the results (00R101)
disconnect swaybars and check for swaybar preload
check alignement
lower left front and right rear spring perch 1/2 turn
raise right front and left rear spring perch 1/2 turn
nate
Old Jun 20, 2003 | 06:57 AM
MaddMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">my car is loose in left hand turns</TD></TR></TABLE>
Sounds like you're ready to run Winston Cu...I mean.... Nextel Cup.
Autobotz8
Mar 2, 2010 10:14 PM
teambk8
May 27, 2009 06:55 PM
roller3804
Feb 7, 2006 10:52 AM
narib2001
Dec 30, 2003 09:57 PM
pucho
Sep 23, 2002 11:38 AM
