Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Auto-x alignment?
Old Aug 27, 2002 | 06:53 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Auto-x alignment?
I'm fixing to pick up an extra set of rims for the R so now I'm thinking about alignment changes before events since I won't be using up my daily driven tires going to and from the track. I don't know much about it in terms of what is radical and not. What is a good setup to start with for a stock R? I will have to drive it to the track so I need some stability. Oh and can I trust just any place or should they be using a certain type of equipment? Thanks.
[Modified by ActiveAero Ninja Edition, 9:53 AM 8/27/2002]
Old Aug 27, 2002 | 06:58 AM
Solracer's Avatar
Default Re: Auto-x alignment? (ActiveAero Ninja Edition)
Ususally most honda respond well to 1/8 total toe out in the front and 0 total toe in the rear.
Old Aug 27, 2002 | 09:26 AM
Hracer's Avatar
New User
Default Re: Auto-x alignment? (Solracer)
I've been autocrossing an itr for three years and I haven't touched the alignment yet. Maybe it could help, but the car just handles so well as it is that I'm afraid to screw it up. A popular autox setup is 1/8th toe out front, 0 rear as someone mentioned and that's what I set on my talon.
Old Aug 27, 2002 | 10:25 AM
Cosworth's Avatar
Default Re: Auto-x alignment? (Hracer)
Yeah, but Alex is a super-driver... he could probably drive a pinto and win DS class. Ok, maybe that's a bit far fetched.
Brock - are you planning on running race tires? If just sticking with street tires, I would do 1/8 out on the front like what other's suggested. However, I agree with Brock that an R is a very well setup car from the factory.
Old Aug 27, 2002 | 10:36 AM
RineRacing's Avatar
I have my car set to 0 toe front and back for the street. When I get to the autocross I rotate one tie rod two full rotations (guessing about 1/8 toe out). The steering wheel will sit crooked but when you're done reverse the rotations and the toe will be set back to 0 and the steering wheel will be centered agiain.
Old Aug 27, 2002 | 12:39 PM
thecaptain's Avatar
Default Re: Auto-x alignment? (Geratol)
2 full rotations?? I would think thats a whole lot more than 1/8!
Old Aug 27, 2002 | 01:03 PM
RineRacing's Avatar
Default Re: Auto-x alignment? (thecaptain)
Whatever it comes out to be the car turns in far better then it used to eliminating a lot of the push I used to have in turns.
Old Aug 27, 2002 | 08:33 PM
MattG's Avatar
New User
I had the toe adjusted and the steering response was much improved. I would recomend it.
Go to a place with good equipment and perferably a place that knows the sport. Call your SCCA region executive and ask if any shops in the area offer special autocross services.
Ahknodd
17
May 9, 2008 01:02 PM
Tricid
May 20, 2007 09:24 AM
Black R
May 24, 2003 03:49 PM
sfr4dr
Apr 3, 2003 03:11 PM
Zorro
Feb 21, 2002 09:17 AM
