wheel alignment help
Hello,
I am heading down to VIR this weekend and I am going to get a wheel alignment tonight.
What do I want to run? toe in???
My ITR is used as my daily driver, auto-x and some track days.
What do you guy recommend for this???
thanks
thanks
when the dealer first put it up on the rack, the rears were set at toe-in from the factory. I was recommended a zero toe set up in the rear by local autox legend, Tom Smith. This set up has worked out very nicely for me
It really depends on what kind of turning behavior you like with your car.
A safe approach would be front zero toe and rear toe in (factory spec). If you want to be more aggressive (consider you have the required skill level), run zero or toe out in the rear to get a little more oversteer when exiting a turn.
Personally I run zero toe front and rear, but I also have camber adjustments so there're more variables in the equation. (camber: -2 front, -2 rear) After some more testings, I would know if I need to dial out my rear camber to 1.5.
schumi
21
Jul 14, 2006 05:19 PM
rambler
Feb 29, 2004 02:05 AM
B18C5-EH2
Aug 19, 2003 07:57 AM
shi - who likes this set up on 234
