Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Alignment on Rex
Old Feb 13, 2006 | 04:08 PM
94accordsedan's Avatar
Banned
Default Alignment on Rex
Searched...
Got a variety of answers, what would be a decent setting on the car. (Not worried about tire wear.) The guy we are taking it to says he knows what to set it to, but I am paranoid so I'd rather be certain.
Old Feb 13, 2006 | 04:58 PM
fireant's Avatar
Default Re: Alignment on Rex (94accordsedan)
I'd say a good starting point is a bit of toe out up front, like 1/16" and zero in the rear...with a plan to toe the rear in a teeny bit if the car is too squirrelly.
Old Feb 13, 2006 | 05:51 PM
STS_Underdog's Avatar
Default Re: Alignment on Rex (fireant)
Don't be afraid to play with rear camber as well, it can make a huge difference in how well the car rotates. You don't need pimpy camber adjusters, just shim out the upper control arm mount with a washer under each bolt to reduce camber and loosen the car up.
Old Feb 13, 2006 | 06:04 PM
MattP's Avatar
Default Re: Alignment on Rex (STS_Underdog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STS_Underdog &raquo;</TD></TR><TR><TD CLASS="quote">Don't be afraid to play with rear camber as well, it can make a huge difference in how well the car rotates. You don't need pimpy camber adjusters, just shim out the upper control arm mount with a washer under each bolt to reduce camber and loosen the car up.</TD></TR></TABLE>
Can't in stock class.
Old Feb 13, 2006 | 06:17 PM
Default Re: Alignment on Rex (MattP)
My bad, I see CRX and automatically think STS2. Sorry! For stock class I'd bet you're going to want some toe out in the rear. When we ran the Civic's in HS we maxed out the rear toe (~1/2"). That may be too much for the shorter wheelbase of the CRX but I'd be willing to bet you'll want to run at least a little to help the car rotate.
Old Feb 13, 2006 | 06:20 PM
Banned
I know it would make sense to run STS2... but I gotta learn how to drive the damn thing so I am staying stock in 06. (The method worked well on the Accord, did 25 races in it completely stock and learned a lot.)
I don't think rotation will be a problem, people seem to say the CRX is rather tail happy. Not sure if we'll get alignment done on time, worst case I can start with an OEM set up and start going from there.
Old Feb 13, 2006 | 06:27 PM
Default Re: (94accordsedan)
Stock is definitely a smart way to go, I spent several years there before ST* came along. Definitely gets rid of a lot of the variables!
Old Feb 13, 2006 | 08:42 PM
fireant's Avatar
Default Re: (STS_Underdog)
you find even with stock suspension it will spin readily if you are on the original rear trailing arm bushings.
Old Feb 14, 2006 | 04:10 AM
MattP's Avatar
Default Re: (fireant)
Got that right. Mine were torn to shreds on a 74k mile car driven by two retirees since it was new. Snap-oversteer city.
Old Feb 14, 2006 | 05:48 PM
Targa250R's Avatar
be professional
Run 1/8" out front, 1/16" out rear. Anything less and you're a pansy
wannaBjdmca6
Suspension & Brakes
26
Jan 16, 2011 08:24 PM
alexm
Suspension & Brakes
16
Apr 27, 2009 11:52 PM
shadohconspiracy
Nov 2, 2007 02:45 AM
YAH YAH
Suspension & Brakes
May 10, 2007 05:16 PM
Andrew 825SM
Aug 15, 2003 03:16 AM
