alignment: converting from degrees to inches??
er, how do you do it? or maybe some smarter person then me can convert .25 degrees into inches for me?
does -.5 degrees of toe seem like a lot or a little?
nate-who is really surprised at how close the numbers were left to right after doing a hack alignment in his backyard.
There's no definite answer for that cuz it depends on the diameter of the wheel and tire (if I understand it correctly). The bigger the diameter is, the toe readings in inches would be greater even tho the readings in degree are the same.
HTH.
[Modified by Wai, 8:22 PM 11/20/2002]
HTH.
yeah, i was really hoping for the trig formula. i think it's sin (angle) * radius of wheel/tire. if so, it works out to about 1/10" of toe out total. does that sound right?
Having given this very little thuoght, I would probably use the *diameter* of the wheel rather than the radius. Toe is a measurement that compares the front of the wheel to the back of the wheel, not the front to the middle.
Here's a nice little chart I found.
http://www.smart-racing.com/pdf's/To...on%20chart.pdf
Scott
Scott
Actually once you get the 1/10" and do a quick sketch on a piece of paper, you would find that the total toe would be 4/10" (0.4"). Assume x to be the distance from center of hub to center of hub:
x + (1/10 + 1/10)
x - (1/10 + 1/10)
*Total* toe would be [x + (1/10 + 1/10)] - [x - (1/10 + 1/10)] = 4/10
[Modified by Wai, 9:47 AM 11/21/2002]
x + (1/10 + 1/10)
x - (1/10 + 1/10)
This should help:
To convert a known toe setting (call it Ta) and a known tire diameter
(call it Da), use this equation to convert to a different tire diameter
but using the same toe. For those who hate the math, just use the
graph. For those who want the exact number and not interpolate
from a graph use this equation:
(Ta/Da) = (Tb/Db)
Where Ta = known toe setting
Da = known tire diameter
If you want the same toe angle with different tire diameters call
those Tb and Db.
If you do the algebra, you end up with:
Tb = Ta * (Db/Da)
You can see that measuring toe accurately is not something that
you can take for granted.
Note: Taken from http://www.smartracing.net
(Ta/Da) = (Tb/Db)
those Tb and Db.
Tb = Ta * (Db/Da)
Sorry, did not get what you were talking about at first.
