Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
What is Camber? Positive vs Negative Camber Effect
Old Mar 11, 2022 | 01:18 AM
MaXpeedingRods's Avatar
Default What is Camber? Positive vs Negative Camber Effect
Negative vs. Positive camber
Changing camber using your camber plates allows you to run more negative camber than stock. Negative camber is good for cornering performance because it improves cornering grip. Negative camber helps your vehicle achieve the ideal tire contact patch during cornering. Since the tire now leans more towards the inside of the vehicle, the outside wheel in the corner will gradually edge back towards zero camber. This means that your tire will sit mostly flat and flush against the road surface as you speed through the corner, giving you the maximum grip your tire size can achieve. However, too much camber can result in negative performance and reduced contact patch. In general, most performance suspension setups benefit from anywhere between -1 and -2.5 camber. Anything beyond this is usually done for cosmetic purposes of vehicle “stance” and does not positively impact cornering performance.
Positive camber is rarely seen on cars nowadays; it was more common on older vehicles that needed it to compensate for suspension shortcomings or lighten up the steering wheel, which made low-speed manoeuvering in cars without power steering easier.
MaXpeedingRods Camber plates features
  • All MaXpeedingRods camber plates are high precisions CNC cut from high-grade aluminum alloys that offer high strength, low weight, and rust-free.
  • MaXpeedingRods camber plates are equipped with high-strength, high-quality hardware that is zinc-plated to prevent rusting.
  • All our camber plates feature high-precision CNC cut or laser etched high-visibility markings to ensure you can always accurately set your camber to the desired levels.
  • Available with rubber or pillowball mounts, MaXpeedingRods camber plates are a great choice for a wide variety of different applications. Our pillow-ball or spherical bushing top mounts are teflon coated to ensure longevity minimize friction and radial forces exerted on your suspension, which provides ultimate performance.
scartail
Suspension & Brakes
Nov 4, 2006 04:19 AM
vdub08
Suspension & Brakes
19
Sep 3, 2005 01:14 PM
Kyles ej1
26
Nov 19, 2004 06:09 AM
AcCO12D95
Jun 12, 2004 10:48 AM
ALF
Aug 16, 2001 05:47 PM
