Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
PWR Intercooloer and Radiator Pricing
Old Feb 9, 2004 | 01:26 PM
  #76
b16hybridsol's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (earl)
can you do custom radiators, cause i need like a smaller radiator for my teg, i'm not worried about mounting points but i need it to be at the most 12.5 inches wide and have a dual core design, or if you've got something that could mount in between the radiator support
Old Feb 10, 2004 | 04:32 AM
  #77
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (b16hybridsol)
A few off sized radiators
A custom built radiator would cost around $500
Old Feb 18, 2004 | 12:05 AM
  #78
Kwuaymaikrup's Avatar
Great seller and PWR's work is top notch
Old Feb 18, 2004 | 03:15 PM
  #79
Boosteddc2gsr's Avatar
when i get paid i will buy
Old Feb 18, 2004 | 04:46 PM
  #80
acy76's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">Have a radiator for a 1993 Integra? Will the 1994 model fit?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">If you can fit the stock 94 radiator, the pwr will fit also</TD></TR></TABLE>
Any pictures available of the 94+ integra model? I've got a 91 and would like to use a PWR later this spring when the new engine goes in. Wondering what the differences are?
Old Feb 18, 2004 | 09:19 PM
  #81
svpAMhatch's Avatar
Old Mar 18, 2004 | 05:54 PM
  #82
boostdGS's Avatar
I'm really interested in seeing the pictures some of the Air to Air intercoolers when the inlet and outlet on oposing sides of the core. ie. b-series fmic.
What I'm wondering, is if the intercoolers are coming with custom made endtanks from you, or if they are coming straight from PWR with their nice, smooth endtanks that are in the middle of the core. Like this 1
Old Mar 26, 2004 | 07:53 AM
  #83
SlowTeg's Avatar
Pm'ed you..
Old Mar 26, 2004 | 09:35 AM
  #84
Kutsuju_SLeePER's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (SlowTeg)
Hey Earl...
Ok so let me get it straight...Im boosting my GSR TEG and theres very little room to play with...I can use the PWR Radiator for the Civic and it will bolt up Fine and Run no prolbems correct....It would be the same size as the INtegra one would be except its not as long. just fatter right?
Old Mar 31, 2004 | 08:25 AM
  #85
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (Kutsuju_SLeePER)
The PWR Civic radiator has the same mounting brackets and overall sizing as the stock Civic except that it is a dual core and is aluminum. If a stock Civic would work for your application, the PWR will also. You may need to make a simple mounting bracket to install the civic properly..not sure.
Old Mar 31, 2004 | 08:27 AM
  #86
earl's Avatar
Default Re: (boostdGS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostdGS &raquo;</TD></TR><TR><TD CLASS="quote">I'm really interested in seeing the pictures some of the Air to Air intercoolers when the inlet and outlet on oposing sides of the core. ie. b-series fmic.
I sell the PWR intercoolers with custom made end tanks but will also start to sell the units with premade tanks. Both will be available.
Old Mar 31, 2004 | 09:33 PM
  #87
sibicguy's Avatar
Default Re: (earl)
Thanks for the info Earl!
Modified by sibicguy at 6:22 AM 4/23/2004
Old Apr 1, 2004 | 01:52 PM
  #88
EFb18b's Avatar
Default Re: (sibicguy)
I got a couple of questions for ya earl: If I were to get a 6x10 air/water ic, should I run some kind of bypass to go straight from the holding tank to the ic back to the tank or should I keep the water flowing through the heat exchanger while I'm at the track? Also, how big of a heat exchanger should I get and do I need a fan?
thanks,
Chris
Old Apr 11, 2004 | 05:31 PM
  #89
ooairewreckoo's Avatar
how do i order a pwr radiator? I need to buy one with in the week.. pm me about details. thanks
Old Apr 14, 2004 | 10:36 PM
  #90
sibicguy's Avatar
Default PWR Intercooloer and Radiator Pricing
Bump
Earl
Modified by sibicguy at 7:01 AM 4/22/2004
Modified by sibicguy at 6:21 AM 4/23/2004
Old Apr 24, 2004 | 07:20 PM
  #91
SlowTeg's Avatar
Bump for a good price and good seller. Placing my order today.
-Mike
Old Apr 24, 2004 | 07:44 PM
  #92
earl's Avatar
Default Re: (Redlineracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redlineracer &raquo;</TD></TR><TR><TD CLASS="quote">I got a couple of questions for ya earl: If I were to get a 6x10 air/water ic, should I run some kind of bypass to go straight from the holding tank to the ic back to the tank or should I keep the water flowing through the heat exchanger while I'm at the track? Also, how big of a heat exchanger should I get and do I need a fan?
thanks,
Chris</TD></TR></TABLE>I would do some kind of valve where you could switch to the ice tank when you need it and run water thru the heat exchanger the rest of the time. If you buy the pwr heat exchanger kit, it comes with a fan.
Old Apr 24, 2004 | 10:39 PM
  #93
accordselux's Avatar
Me Gusta History
Default Re: (earl)
I have a question that's probably been asked before but i just can't find it right now...
If i'm running low boost (&lt;10psi) and I don't have anything fancy in the engine bay, how does the barrel intercooler hold up? Someone told me I'd be better with a front mount because theyll overheat in the summertime. Will the heat exchanger eliminate this problem?
Thanks
Old Apr 25, 2004 | 07:14 PM
  #94
earl's Avatar
Default Re: (accordselux)
If you do not have a set up for max power, it is much simpler to run an air to air. If you are trying to hide the fact that you have a turbo, the water to air is great. It will not overheat in the summer time anymore than an air to air would.
Old Apr 27, 2004 | 11:35 PM
  #95
earl's Avatar
Default Re: (earl)
https://honda-tech.com/zerothread?id=847690
Check out the huge price decreases on PWR intercoolers with cast end tanks, save $100 or more on the intercoolers with mirror POLISHED end tanks.
Old Apr 6, 2006 | 05:31 PM
  #96
b20xx's Avatar
Default Re: (earl)
Earl rocks! Laskey Racing and PWR radiators kick donkey *****! Will be in touch shortly so I can order my next radiator.
Old May 9, 2006 | 09:41 PM
  #97
earl's Avatar
Default Re: (b20xx)
thanks
Old May 27, 2006 | 10:06 AM
  #98
Default Re: (earl)
looking to get the 6x10 AWIC. Would you happen to be in today so i can order, or should i wait till tuesday?
Old Jun 6, 2006 | 10:17 AM
  #99
earl's Avatar
Default Re: (b16hybridsol)
call whenever you like
Old Dec 27, 2006 | 01:54 PM
  #100
ninesecrx's Avatar
Default Re: (earl)
If you guys need these in the future, please call or IM me.
Thanks, Mike
