Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
PWR Intercooloer and Radiator Pricing
Old Dec 19, 2003 | 05:06 AM
  #51
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (earl)
Pix of down flow design on intercooler
6x18 core (10x18 overall) runs $499
6x22 core (10x22 overall) runs $599
Choice of outlet size and location (including backdoor design)
Old Dec 28, 2003 | 01:27 PM
  #52
96 Ls lnTeG's Avatar
Well Prolly gonna be getting a Radiator (For My Teg) does it com with a radiator cap?? if I wanted to use a spal fan which one would you reccomends do you sell one with it
Old Dec 28, 2003 | 06:19 PM
  #53
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (96 Ls lnTeG)
Comes with cap and drain plug. Any aftermarket fan will work fine. Pwr is not selling fans now.
Old Dec 28, 2003 | 07:31 PM
  #54
Pm'ed you
Old Dec 28, 2003 | 07:46 PM
  #55
FredoSP's Avatar
bump for earl, I got mine 2 months ago ..it should go on VERY soon! pics to come!
Old Dec 31, 2003 | 12:11 AM
  #56
Default Re: PWR Intercooloer and Radiator Pricing (FredoSP)
Pm'ed You about a radiator
Old Dec 31, 2003 | 07:39 AM
  #57
earl's Avatar
back at you
Old Jan 2, 2004 | 01:51 PM
  #58
true's Avatar
Does anybody have any size specs on the PWR radiators? Specifically, I'm looking at 95 Honda Del Sol VTEC for a custom application. Length, width, height, core thickness etc.. would be appreciated. Thanks.
Old Jan 2, 2004 | 05:42 PM
  #59
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (true)
The PWR civic and Integra radiators have identical dimensions (except for being dual core) and mounting brackets as the oem radiators. If oem will work, pwr will work.
Old Jan 2, 2004 | 07:04 PM
  #60
94vtirozguy's Avatar
pwr does have a prelude radiator, not sure if it for sohc or the non vtec dohc.
They don't have one for the vtec (h22) prelude but they are making it up as we speak mine being the prototype, i should have it by the 7th of january.
Old Jan 3, 2004 | 08:51 AM
  #61
seen4ever's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (94vtirozguy)
which of the water to air kits would you recommend for a turbo b18c1 in the low 400whp range? this is going into a hatch, so would I attempt to mount the heat exhanger where the AC condensor was? Just wondering the dimensions of it, since I don't know if my manifold will allow it.
Old Jan 3, 2004 | 05:57 PM
  #62
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (seen4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote">which of the water to air kits would you recommend for a turbo b18c1 in the low 400whp range? this is going into a hatch, so would I attempt to mount the heat exhanger where the AC condensor was? Just wondering the dimensions of it, since I don't know if my manifold will allow it.</TD></TR></TABLE>You need the 6x8 or 6x10. The 4" diameter w/a really only good for about 350whp
Old Jan 6, 2004 | 12:18 PM
  #63
JDMHN8's Avatar
Have a radiator for a 1993 Integra? Will the 1994 model fit?
Old Jan 6, 2004 | 10:26 PM
  #64
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (JDMDA9)
It would not be a direct drop in
Old Jan 6, 2004 | 11:30 PM
  #65
Dr. EKology's Avatar
Hey Earl, how would these PWR Radiators compare to say a Fluidyne, or C&R radiator? I am looking into a radiator and I'm just wondering which is the best to go with. Thanks a lot man!
Old Jan 7, 2004 | 08:03 AM
  #66
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (EVIL_EKology)
The good thing about PWR is that they include all the stock mounting brackets. The in/outlets are B series sized. The cores feature 18 fins per inch as compared to 16 fins per inch from other manufacturers. PWR's come with caps and drain plugs included. Also they have extra bracing on the side to help in case of head gasket failure. They don't baloon out like the fluidynes.
Old Jan 7, 2004 | 10:24 AM
  #67
gsrhunny's Avatar
Is the PWR radiator bigger then the oem? Reason I ask is that with the stock setup (radiator & fan) I have a tight fit already and don't know if a bigger radiator would fit. It's a 2000 Acura GSR with Greddy turbo. Do you also sale the thin fans for the radiator, if so how much? Thanbks
Old Jan 7, 2004 | 04:55 PM
  #68
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (gsrhunny)
It is a double core radiator so it is a little thicker. PWR does not have thin fans
Old Jan 10, 2004 | 08:17 AM
  #69
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 &raquo;</TD></TR><TR><TD CLASS="quote">Have a radiator for a 1993 Integra? Will the 1994 model fit?</TD></TR></TABLE>If you can fit the stock 94 radiator, the pwr will fit also
Old Jan 10, 2004 | 08:31 AM
  #70
delslowh23's Avatar
that air to water is 6" outside to outside?
Old Jan 10, 2004 | 08:10 PM
  #71
earl's Avatar
Default Re: PWR Intercooloer and Radiator Pricing (delslowh23)
the diameter is 6". I have never really checked it however.
Old Jan 28, 2004 | 03:58 PM
  #72
delslowh23's Avatar
can you find out please?
Old Jan 29, 2004 | 08:15 AM
  #73
earl's Avatar
6"
Old Feb 4, 2004 | 06:19 PM
  #74
delslowh23's Avatar
thx for the info
Old Feb 7, 2004 | 11:05 PM
  #75
earl's Avatar
just a bump
