Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
LS/VTEC Easy Swap Kit - Golden Eagle
Old Oct 17, 2006 | 05:02 PM
  #101
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (jdmstylesi)
Old Oct 20, 2006 | 01:41 PM
  #102
jdmstylesi's Avatar
you can order online also...
http://www.robearracing.com
Old Oct 23, 2006 | 11:23 AM
  #103
jdmstylesi's Avatar
Old Oct 24, 2006 | 11:18 PM
  #104
reaglebeagle's Avatar
bumpland!
Old Oct 26, 2006 | 04:51 PM
  #105
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (reaglebeagle)
Old Nov 15, 2006 | 10:24 PM
  #106
jdmstylesi's Avatar
Old Nov 16, 2006 | 07:33 PM
  #107
jdmstylesi's Avatar
Bump for LS/VTEC swaps!!
Old Dec 13, 2006 | 09:03 PM
  #108
jdmstylesi's Avatar
Old Dec 13, 2006 | 09:21 PM
  #109
JFG Kevin's Avatar
i'm going back and forth between 84.5mm and 85mm...But either one i choose do i have to use a 84mm hg for 84.5mm or i can use 85mm hg for 84.5mm?
Old Dec 14, 2006 | 01:18 PM
  #110
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (JFG Kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JFG Kevin &raquo;</TD></TR><TR><TD CLASS="quote">i'm going back and forth between 84.5mm and 85mm...But either one i choose do i have to use a 84mm hg for 84.5mm or i can use 85mm hg for 84.5mm?</TD></TR></TABLE>
gotcha back!!
Old Dec 16, 2006 | 12:40 AM
  #111
JFG Kevin's Avatar
Just placed an order.....=p
Old Dec 16, 2006 | 06:10 AM
  #112
2001B18C1GS-R's Avatar
is there a way that i can order just the sandwoch plate and the stainless stell line only thanks
Old Dec 18, 2006 | 09:04 AM
  #113
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (2001B18C1GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001B18C1GS-R &raquo;</TD></TR><TR><TD CLASS="quote">is there a way that i can order just the sandwoch plate and the stainless stell line only thanks </TD></TR></TABLE>
of course, call us up!!
Old May 11, 2007 | 09:36 AM
  #114
jdmstylesi's Avatar
Old May 15, 2007 | 07:55 AM
  #115
Golden Eagle's Avatar
bump
Old May 18, 2007 | 10:27 AM
  #116
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (Golden Eagle)
bump
Old May 23, 2007 | 12:57 PM
  #117
jdmstylesi's Avatar
put the weekend orders in!!
Old May 23, 2007 | 01:00 PM
  #118
bump
Old May 29, 2007 | 04:08 PM
  #119
jdmstylesi's Avatar
Old May 29, 2007 | 05:28 PM
  #120
ekek888's Avatar
price still the same? will u collect sales tax?
Old May 29, 2007 | 05:34 PM
  #121
Coopler's Avatar
I'm in the middle of deciding what to do with my 98 4DR LX... I was hit in my front passenger quarter panel totaling my bumper, hood, front quarter panel, windshield and front passenger door. I don't have alot of money so I've been trying to find a rolling shell with a straight frame to swap my motor and transmission with. I found a 96 EX V-TEC and am about to buy it. It has a spun bearing, so it needs new bearings, main rod, and the crank either needs to be replaced or turned. I was wondering if anyone knew whether or not I can replace the bearings, rod and crank on the EX with the ones from my LX. I only ask this because I would like to keep the V-TEC instead of swapping the entire engine for my dinky 106 hp d16. Any ideas?
Old May 29, 2007 | 07:42 PM
  #122
Sumslapper's Avatar
Year 3030
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (Coopler)
pmed need asap car is leaking oil bad!!
Old May 30, 2007 | 09:27 AM
  #123
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (Sumslapper)
Old Jun 7, 2007 | 07:52 AM
  #124
bump
Old Jun 7, 2007 | 08:46 AM
  #125
pslieu's Avatar
why do i have to leave comments just to be in this site?
