Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
LS/VTEC Easy Swap Kit - Golden Eagle
Old Aug 11, 2004 | 04:56 PM
jdmstylesi's Avatar
Default LS/VTEC Easy Swap Kit - No Machining Required!!
RoBear Racing is offering a great kit for the LS/VTEC setup.
- We now have a Full Vtec Conversion System for people that want to use an LS/VTEC or B20/VTEC set-up.
- This kit is the easiest and most complete way to supply oil to the head without any machining required and is very clean and reliable.
The kit includes:
- 1. Golden Eagle Vtec Conversion Sandwich Plate with a -6AN fitting for the plate and head.
- 2. -6AN steel braided teflon hose for oil supply
- 3. Golden Eagle Vtec Conversion Dowels for proper alignment of the head and block without machining
- 4. 1/8 NPT tap and plug for the oil port in the head
- 5. Golden Eagle worked factory head gasket with any bore size and dowel holes opened for any application
-When we say " NO Machining " we mean that there is no reason that anyone cannot do this kit in their own garage. - The only thing that must be done is tapping the head for the plug
- The VTEC line and fitting all use existing ports with no need to do anything else.
- Sold as a kit with full instructions.
- Individual parts can be purchased separately.
Price for HT members only: $225 SHIPPED FOR FREE!!!
LIMITED TIME SPECIAL!!!
GOLDEN AGLE HP HEADSTUD KIT
Golden Eagle "HD" Headstuds
Glass bead finish for more accurate torque
- Hex Head Top
- Dog Point Bottom
B16, B18C
K20/K24
Ecotec 2.2
Order Here: http://robearracing.com/search...studs
GOLDEN EAGLE TOW REAR TOW HOOK
Golden Eagle Billet Aluminum T6061 Tow Hook
Colors: Polished, Black, Red, Blue, Gunmetal
Available for: 88-00 Civic/Integra & 06-up Civic/Fit
Order Here: http://robearracing.com/cat_tow.cfm
GOLDEN EAGLE VACCUUM MANIFOLD
-Specifically designed for turbo charged engines that require multiple vacuum sources. Also works with individual throttle bodies.
-Precision CNC machined from 6061T6 billet aluminum
-Has six ( 6 ) usable 1/8 NPT ( Pipe Thread ) ports for items such as fuel pressure regulator, blow-off valve, MAP sensor, boost controller, boost gauge and any other engine components that require a vacuum source
-Every Vacuum Manifold comes complete with installation instructions and mounting hardware
-All Golden Eagle Mfg. Vacuum Manifolds carry a limited 1 year warranty
Colors: Red, Blue, Titanium, Polished, Black
Order Here: http://robearracing.com/pd_golden_eagle_vacuum.cfm
Thanks!!
http://www.robearracing.com
Modified by jdmstylesi at 11:36 AM 8/31/2007
Old Aug 12, 2004 | 07:05 AM
X-Mazda 3 Racer's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (RobearRacing)
Bump for great dealer!!!
Old Aug 12, 2004 | 04:55 PM
tunerz's Avatar
got to have 1. ttt
Old Aug 16, 2004 | 10:54 AM
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (tunerz)
PM sent
Old Aug 17, 2004 | 08:43 PM
m00tjam's Avatar
total altpgether shipped to 95119
Old Aug 18, 2004 | 07:49 AM
Robstunner4's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (m00tjam)
this deal still valid???
im very interested
Old Aug 18, 2004 | 07:57 AM
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (Robstunner22)
Bump!
Disco Monkey's Avatar
just got my kit in the other day.
very nice.
thanks
Old Aug 18, 2004 | 09:55 AM
jdmstylesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m00tjam &raquo;</TD></TR><TR><TD CLASS="quote">total altpgether shipped to 95119</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robstunner22 &raquo;</TD></TR><TR><TD CLASS="quote">this deal still valid???
im very interested
Sure is.
Call us up at 909-982-4927 or PayPal - $229 to robearracing@verizon.net
Old Aug 18, 2004 | 03:04 PM
butters's Avatar
please check pm's
Old Aug 19, 2004 | 10:23 AM
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (butters)
got it, going out today!
Old Aug 23, 2004 | 02:30 PM
tunerz's Avatar
bump up
Old Aug 24, 2004 | 04:49 PM
butters's Avatar
got my kit today free bizump *waiting for ge headstuds*
Old Aug 26, 2004 | 12:17 PM
jdmstylesi's Avatar
Thanks!
HD studs on the way!
Old Aug 27, 2004 | 07:38 AM
Great guys to deal with. Bump for a great dealer!
Old Aug 31, 2004 | 04:07 PM
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (GoldenEagleMfg.com)
bump
Old Aug 31, 2004 | 08:48 PM
justinh595's Avatar
Will this still be up a couple weeks from now?
Old Sep 1, 2004 | 11:04 AM
jdmstylesi's Avatar
Default Re: LS/VTEC Easy Swap Kit - No Machining Required!! (justinh595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinh595 &raquo;</TD></TR><TR><TD CLASS="quote">Will this still be up a couple weeks from now?</TD></TR></TABLE>
gotcha back with info
Old Sep 7, 2004 | 11:23 AM
jdmstylesi's Avatar
bump
Old Sep 13, 2004 | 09:39 AM
jdmstylesi's Avatar
bump
Old Sep 20, 2004 | 11:18 AM
jdmstylesi's Avatar
bump, in stock!
Old Sep 24, 2004 | 10:08 AM
jdmstylesi's Avatar
on sale!
Old Sep 28, 2004 | 02:13 PM
jdmstylesi's Avatar
bump
Old Oct 4, 2004 | 02:42 PM
jdmstylesi's Avatar
bump
Old Oct 8, 2004 | 07:03 AM
TTT
