▐▐▐▐▐ JASE Composites 3 piece Fiberglass Front ends. Available NOW ▐▐▐▐▐
Available for: 92-95 Civic Coupe and Hatchback / EK 99-00 Civic Coupe/HB / 99-00 Integra / 88-91 CRX
We’re excited to offer the JASE Composites 3 piece front end for the 92-95 Civic Coupe/HB, 96-01 Civic Coupe/HB and 98-00 Integra. It’s made out of a durable, high quality, thick fiberglass material. The 3 piece front end consists of a front bumper that has been redesigned and extended about 1.5” to clear 4.5” thick intercoolers. The front opening shroud can also be trimmed to fit depending on how thick and how far you have your intercooler extended forward.
The fenders extend to clear 24.5”, 25”, and 26”* tall drag racing slicks. The fenders are designed to clear 9” wide tires on the common 13x7.5, 13x8, or 15x8 wide wheels with 5” backspace. 26” tall slicks will also clear depending on the wheel backspace and width. Extreme rim width and backspace such as 15x10 with 4” backspace may have clearance issues, but the fenders can be modified on the lip to help clear wider tire/wheel setups.
Keep in mind, these prices are only good until Feb 1st. Prices will go up $150 respectively after Feb 1st. The $1050 shipped price applies to the 48 states and is an introductory special. These are not the normal front ends you're used to seeing. They are made with a better quality fiberglass and with much higher quality control than what has been previously offered in the market.
FOR THE FASTEST REPLIES REGARDING ORDERING, PLEASE E-MAIL SALES@JASECOMPOSITES.COM. IT'S 2-4 WEEKS FROM ORDERING TO DELIVERY.
88-91 CRX: $1050 shipped in the 48 states. $1350 shipped to Canada.
92-95 Civic Coupe/Hatchback: $1050 shipped in the 48 states. $1350 shipped to Canada.
96-00 Civic Coupe/Hatchback: $1050 shipped in the 48 states. $1350 shipped to Canada.
98-00 Integra: $1050 shipped in the 48 states. $1300 shipped to Canada.
Pics will be added very soon...
EF
EG
EK
EK WIDE
INTEGRA
FAQ's
Is this available in Carbon fiber?
No as of now.
Is this a bolt on affair?
We suggest using someone familiar with fiberglass to install the kit. It will not line up perfectly like OEM out of the box. Every car is different, some have been in accidents, etc... It would be next to impossible to make perfect bolt on fiberglass front ends so you may need to do a little bit of modification to get it perfect.
How will this mount compared to the stock bumpers and fenders?
The fenders still retain the stock tab locations which you have to drill before putting on the kit. The fender will bolt down with the OEM 10mm bolts.
The front bumper also retains the stock tab locations on the top where it bolts on the radiator support. You will also need to drill holes where the fender and bumper meet. We recommend a washer, bolt and wingnut to keep them together and in place. This also makes it easy to unbolt and take off the bumper.
How is the kit shipped? UPS? FedEx?
Due to the size of the box we ship it in, it has to be shipped by Freight. We work with several freight companies and will get you the best price possible.
We can also ship internationally.
What tire size will it clear?
The kit was fitted with 24.5x9x13 MT, 25x8.7x13, 26x8.5x13 and 26x9x15 tires. They fit under the fenders. These were using 8” wide rims with 5” backspace. The only time that there maybe a clearance issue is if you’re using a 10” wide rim with a low backspace. A 4” backspace will stick out the fender for sure. 5” backspace on a 10” wide rim, will require trimming of the inside fender lip. Any aggressive/extreme rim backspace setup may not be able to “dump” the car lower.
JASE COMPOSITES: 3 Piece FIBERGLASS Racing Front End
EF
EG
EK
EK WIDE
INTEGRA
FAQ's
No as of now.
Re: ▐▐▐▐▐ JASE Composites 3 piece Fiberglass Front ends. Available NOW ▐▐▐▐▐
e-mail sales@jasecomposites.com to order!!
please e-mail sales@jasecomposites.com to order!!
ChrisMillerRacing
12
04-11-2014 05:43 AM
ChrisMillerRacing
157
03-19-2013 10:05 AM
ChrisMillerRacing
22
09-10-2011 09:59 AM
ExospeedAMcrx
243
01-17-2011 07:48 AM
