Grams Performance Injectors (550cc, 750cc, 1,000cc, 1,150cc, 2,200cc)
Grams Performance is proud to offer the most innovative high-performance fuel injectors for today’s performance vehicles. Premium materials, advanced manufacturing techniques, and stringent quality control procedures make Grams Performance the leader in high-performance fuel injectors.
Grams Performance accomplishes this with its high-impedance Bosch Motorsports EV14 fuel injectors that are modified for high-performance use. Each injector is individually balanced, flow tested, and dynamically matched for characterization within one percent of one another. To ensure leak-free operation and optimal performance, each injector is then pressure tested.
Grams Performance injectors are cold-cut with diamond grinders in less than three seconds for high precision without “pre-seating.” Abrasive cutting creates heat, which leads to poor spray patterns and the need for competitors to pre-seat their injectors to reduce distortion. Each injector is also fitted with high-quality Viton O-rings that are resistant to extreme temperatures and harmful oils found in some fuels.
Each injector set includes dead time compensation values to help ensure consistent air/fuel ratios and optimal performance when tuning. Grams Performance Fuel Injectors are carefully tested and matched in controlled laboratory environments using state-of-the-art equipment and are subjected to rigorous dyno, street, and race track testing to ensure proper performance in the most extreme conditions.
Members get 10% off Grams Performance Injectors and/or Grams Performance Fuel pumps when you use coupon code: GRAMSGOODS2013
FEATURES:
High-impedance design (no resistor box required)
Cold-machined tips for high-precision operation
Ultra-fast solenoids for precise fuel metering
Linear response across wide range of operating conditions
All injectors balanced, blueprinted, and matched within one percent
Compatible with all known fuels including gasoline, methanol, and ethanol
Unmatched cylinder-to-cylinder consistency and optimal idle quality
Visit the Grams online store to purchase:
http://cms.gramsperformance.com/
FEATURES:
importdps
12-09-2012 09:45 PM
boost_is_best
02-28-2006 05:02 PM
ATS*Mark
08-18-2004 09:16 PM
