Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
CP Pistons
Old Jan 11, 2004 | 08:21 AM
  #26
H22EK9's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> You are probably looking at $600 plus a months build time on a piston like that.</TD></TR></TABLE>
okay well I have been thinking about some stuff since I asked previous question. Would it be as beneficial for the gas porting on a NA motor as opposed to a FI setup.
And would probably rather end up going with a 89mm bore instead.
What part takes so long for the build time, is it a certian aspect or just a combination of things.
Old Jan 12, 2004 | 06:24 PM
  #27
Dyno Queen's Avatar
Default Re: (H22EK9)
Earl i need some 83mm 9.1 CP's for a GSR let me know how to pay, and also the Pauter rods and ACL bearings, give me a good package price haha
Old Jan 12, 2004 | 07:23 PM
  #28
Dyno Queen's Avatar
Default Re: (Dyno Queen)
Old Jan 13, 2004 | 02:08 PM
  #29
4-banging's Avatar
Default Re: CP Pistons (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Valdez &raquo;</TD></TR><TR><TD CLASS="quote">Is there an 85mm 9-1 off the shelf size available from CP?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">absolutely, IM me</TD></TR></TABLE>
can you give us a run-down of the shelf sizes and compression along with the bore size? to keep easier make it on a B18c motor.
thanks
Old Jan 13, 2004 | 06:28 PM
  #30
Dyno Queen's Avatar
Default Re: CP Pistons (4-banging)
dang it! the 83mm CP is out of stock, but Earl is the man and is taking care of me.
Old Jan 14, 2004 | 05:35 PM
  #31
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging &raquo;</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>www.cppistons.com
Old Jan 14, 2004 | 05:36 PM
  #32
Dyno Queen's Avatar
to popular to stay in stock though, haha
Old Jan 27, 2004 | 08:13 AM
  #33
Dyno Queen's Avatar
Default Re: CP Pistons (Dyno Queen)
Got mine today Earl, VERY NICE MAN!!! thanks alot
Mike
Old Jan 28, 2004 | 10:52 AM
  #34
persianprelude's Avatar
Bump for an excellent seller, and sweet pistons!!
Old Jan 29, 2004 | 08:16 AM
  #35
earl's Avatar
Default Re: (persianprelude)
thanks
Old Feb 7, 2004 | 11:18 PM
  #36
earl's Avatar
Default Re: (earl)
cheap bump
Old Feb 8, 2004 | 09:59 AM
  #37
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EK9 &raquo;</TD></TR><TR><TD CLASS="quote">okay well I have been thinking about some stuff since I asked previous question. Would it be as beneficial for the gas porting on a NA motor as opposed to a FI setup.</TD></TR></TABLE>
i would also like to know this!
Old Feb 8, 2004 | 08:52 PM
  #38
earl's Avatar
Default Re: (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
i would also like to know this!</TD></TR></TABLE>That is a great question. I think in an n/a street set-up, I would try the gas ports if I was looking to max out power. I think any extra wear would be insignificant.
Old Feb 8, 2004 | 09:27 PM
  #39
slrh22hatch's Avatar
Default Re: (earl)
can i get a price on a set of cp pistons w/ 9:1 compression for a stock bore b16 and a price of pauter rods to go with them
Old Feb 10, 2004 | 04:40 AM
  #40
earl's Avatar
Default Re: (slrh22hatch)
im sent
Old Feb 15, 2004 | 05:36 PM
  #41
0evilEMPIRE0's Avatar
Default Re: (earl)
sent im
Old Feb 20, 2004 | 02:33 PM
  #42
gelok's Avatar
Default Re: (0evilEMPIRE0)
sir can you give a price on p/n SC7011 w/ rings & wrist pins. Thanks
Old Feb 21, 2004 | 09:19 AM
  #43
Aquafina's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">That is a great question. I think in an n/a street set-up, I would try the gas ports if I was looking to max out power. I think any extra wear would be insignificant.</TD></TR></TABLE>
Brad from RLZ said gas strutted pistons will last about 5,000 (the engine that is) before it needs a rebuild.
Old Feb 22, 2004 | 09:11 PM
  #44
earl's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">
Brad from RLZ said gas strutted pistons will last about 5,000 (the engine that is) before it needs a rebuild.</TD></TR></TABLE>I have a test going in a friends' B series Honda.. He has 22,000 miles. So far so good on the lateral gas ports. Holding compression well.
Does Brad understand that gas ports only affect the upper ring. No need for a rebuild.
Old Feb 22, 2004 | 11:52 PM
  #45
DOMKID's Avatar
Default Re: (earl)
PM a price for SC7136 with wrist pins and rings please. Also, could you run these pistons on stock rods for n/a?
thank you.
Old Feb 23, 2004 | 07:34 PM
  #46
Aquafina's Avatar
Default Re: (earl)
I don't know. You say gas ports, he says gas strutted so they might be different. He worked for Rousch so he should know what he is talking about...
Old Feb 24, 2004 | 02:27 AM
  #47
slowsi00's Avatar
gas porting?
new term to me.
can anyone help explain?
Old Feb 25, 2004 | 11:15 PM
  #48
slowsi00's Avatar
Old Feb 27, 2004 | 06:09 AM
  #49
vtecb20coupe's Avatar
B A N N E D
looking for a 12.5:1 81.5 mm b series piston. price and availability?
Old Feb 28, 2004 | 07:30 AM
  #50
earl's Avatar
Default Re: (slowsi00)
Arrow points to the lateral gas port. They do not fill with carbon quickly like a vertical gas port does
