Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
CP Pistons
Old Nov 30, 2003 | 11:59 AM
earl's Avatar
Default CP Pistons
CP Pistons. I ship ANY part number within one day of order placement. Plus I give you what no one else does...good tech help with your install...someone you can get help from on the spot at any time. Call for pricing.
Old Dec 1, 2003 | 07:04 AM
earl's Avatar
Default Re: CP Pistons (earl)
Some pix of CP Pistons using the lateral gas port option:
Old Dec 9, 2003 | 08:37 PM
incogNitto's Avatar
What are the benefits of lateral gas ports?
Also, where can we get a listing of CP's pistons w/ part numbers?
Old Dec 10, 2003 | 08:11 AM
minivan81's Avatar
Default Re: CP Pistons (incogNitto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incogNitto &raquo;</TD></TR><TR><TD CLASS="quote">
Also, where can we get a listing of CP's pistons w/ part numbers?</TD></TR></TABLE>
Catalog part numbers:
http://www.cppistons.com/PDF%20Files/CPImport.pdf
Old Dec 10, 2003 | 12:52 PM
flip1199's Avatar
Default Re: CP Pistons (minivan81)
how much for custom cp pistons?
Old Dec 10, 2003 | 05:20 PM
earl's Avatar
Default Re: CP Pistons (flip1199)
IM me what you need and I will price it for you
Old Dec 10, 2003 | 05:21 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incogNitto &raquo;</TD></TR><TR><TD CLASS="quote">What are the benefits of lateral gas ports?</TD></TR></TABLE> Tighter ring seal.
Old Dec 10, 2003 | 05:34 PM
AVATAR's Avatar
do you reccommend them on street cars (lateral ports).
Not to be a pain in the *** but can you IM me the prices of your shelved 9.? :1 pistons? Thanks
Old Dec 10, 2003 | 05:51 PM
earl's Avatar
Default Re: CP Pistons (AVATAR)
IM sent
Old Jan 4, 2004 | 09:51 PM
Skinner's Avatar
Is there an 85mm 9-1 off the shelf size available from CP?
Old Jan 4, 2004 | 11:57 PM
94vtirozguy's Avatar
i am after custom made h22 12:1 CR 89mm pistons for NA car
Old Jan 5, 2004 | 08:42 AM
earl's Avatar
Default Re: (94vtirozguy)
IM sent
Old Jan 7, 2004 | 08:08 AM
earl's Avatar
Default Re: CP Pistons (Valdez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Valdez &raquo;</TD></TR><TR><TD CLASS="quote">Is there an 85mm 9-1 off the shelf size available from CP?</TD></TR></TABLE>absolutely, IM me
Old Jan 7, 2004 | 10:56 AM
Charlie Moua's Avatar
IM you
Old Jan 8, 2004 | 08:53 PM
SKDRCR's Avatar
Default Re: CP Pistons (Charlie Moua)
can you sell them swain tech coated and side coated,
is it true that you have to install them in a certian amount of time
if they have been coated?
Old Jan 8, 2004 | 09:39 PM
V-SPEC 1's Avatar
Default Re: CP Pistons (SKDRCR)
can you please IM me for price of 1 set with rings? looking between 10.2.1 to 9.5.1 compression. Thanks mr. Earl.
Old Jan 8, 2004 | 10:05 PM
piscorpio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote"> Plus I give you what no one else does...good tech help with your install...someone you can get help from on the spot at any time. </TD></TR></TABLE>
This is very true, I've pestered earl with a few newb questions, and he has never failed to help me out. Thanks earl!
Old Jan 9, 2004 | 04:14 AM
Default Re: CP Pistons (piscorpio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piscorpio &raquo;</TD></TR><TR><TD CLASS="quote">
This is very true, I've pestered earl with a few newb questions, and he has never failed to help me out. Thanks earl! </TD></TR></TABLE>
ditto! bump for a good guy.
Old Jan 9, 2004 | 06:56 AM
BodyKits NW's Avatar
Bump
Old Jan 9, 2004 | 07:25 AM
earl's Avatar
Default Re: CP Pistons (boostedb20vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedb20vtec &raquo;</TD></TR><TR><TD CLASS="quote">can you please IM me for price of 1 set with rings? looking between 10.2.1 to 9.5.1 compression. Thanks mr. Earl.</TD></TR></TABLE>IM sent
Old Jan 9, 2004 | 07:30 AM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">can you sell them swain tech coated and side coated,
if they have been coated?</TD></TR></TABLE>I'm not sure about that. If I had to guess, I would guess no. Time should not matter. However, the coating on the skirts will wear away over time. I would not use it on a street motor as clearance will increase as the coating wears off. It might be good for a short life drag motor.
Old Jan 9, 2004 | 06:26 PM
1point5CRX's Avatar
i can read your mind
Old Jan 10, 2004 | 04:33 AM
Silverhatch's Avatar
Default Re: CP Pistons (1point5CRX)
Thanks again earl.... I got my pistons yesterday...very nice ..I hear good stuff about these pistons.
Old Jan 10, 2004 | 09:21 PM
H22EK9's Avatar
Hey Earl what would a set of 90mm gas ported pistons with a cr of 12.5:1 cost.
Old Jan 11, 2004 | 07:06 AM
earl's Avatar
Default Re: (H22EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EK9 &raquo;</TD></TR><TR><TD CLASS="quote">Hey Earl what would a set of 90mm gas ported pistons with a cr of 12.5:1 cost.</TD></TR></TABLE> You are probably looking at $600 plus a months build time on a piston like that.
