Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
06+ Civic Performance Parts
Old May 13, 2009 | 05:51 PM
Power2r's Avatar
Former Vendor
Default 06+ Civic Performance Parts
Battery Tie Down
Want to start dressing up under the hood? Well, start by installing a P2R battery tie down. Made out of extremely light, yet incredibly durable, billet material the P2R battery tie down is the perfect accessory for any engine bay.
$29.99
http://powerrevextras.com/catalog/pr...roducts_id=158
Throttle Body Spacer
Increase horsepower and torque with this 3/4 inch throttle body spacer. Tests on a 06 Civic Si produced a 4.5 horsepower gain at the wheels! Our spacer comes equipped with a 1/8th inch NPT threaded port at the bottom that can be used as an extra vacuum port or nitrous. Includes extended bolts, plug, and is polished to a brilliant show-quality shine.
$79.99
http://powerrevextras.com/catalog/pr...products_id=91
Rear Lower Tie Bar
P2R Rear Lower Tie bar will help reduce chassis flex, and provide your car with better cornering ability. Fits 2006+ Honda Civic. Both 2 door and 4 door. All models (Si,EX,LX,DX,etc).
$89.99
http://powerrevextras.com/catalog/index.php?cPath=7
Shift ****
P2R shift ***** are lightweight; however, top heavy to give a nice shifting feel. They are anodized flat black for a stealthy race car look. M10 x 1.5 thread pitch. Fits most Honda/Acura.
$49.99
http://powerrevextras.com/catalog/pr...roducts_id=153
Intake Manifold Gasket
Power Rev Racing intake gaskets will help reduce intake air temperatures by removing the direct connection of the intake manifold to the cylinder head. Made out of our proprietary heat dissipating material the P2R thermal intake gasket creates a thermal barrier that isolates power-robbing heat from traveling to your intake manifold through the cylinder head. Less heat soak means cooler air and more consistent power delivery.
$34.99
http://powerrevextras.com/catalog/pr...products_id=53
Throttle Body Gasket
Power Rev Racing intake gaskets will help reduce intake air temperatures by removing the direct connection of the throttle body to the intake manifold. Made out of our proprietary heat dissipating material the P2R thermal intake gasket creates a thermal barrier that isolates power-robbing heat from traveling to your intake manifold through the cylinder head. Less heat soak means cooler air and more consistent power delivery.
$22.99
http://powerrevextras.com/catalog/pr...roducts_id=108
Short Shifter
P2R Stainless Short Shifter will help reduce the throw on your shifter be approximately 20%. Made out of stainless steel for durability. Slight trimming of shifter box might be required on some vehicles. Fits DX, LX, EX & SI, both 2 & 4 door models.
$54.99
http://powerrevextras.com/catalog/pr...roducts_id=174
Local Pickup Also Available
8874 Miramar Pkwy
Miramar, FL 33025
954-543-5053
Old May 14, 2009 | 07:08 AM
Power2r's Avatar
Former Vendor
Default Re: 06+ Civic Performance Parts
bump
Old May 16, 2009 | 08:01 AM
Power2r's Avatar
Former Vendor
bump
Old May 22, 2009 | 06:47 AM
Power2r's Avatar
Former Vendor
bump,.,.,.
Old May 23, 2009 | 01:32 PM
Power2r's Avatar
Former Vendor
to the top
Old May 28, 2009 | 02:17 PM
Power2r's Avatar
Former Vendor
bbbuuummmppp
Old Jun 1, 2009 | 11:46 AM
Power2r's Avatar
Former Vendor
bump...,,
Old Jun 5, 2009 | 11:42 AM
Power2r's Avatar
Former Vendor
i know there are some fg's on here
Old Jun 12, 2009 | 07:20 AM
Power2r's Avatar
Former Vendor
to the top
Old Jun 22, 2009 | 05:04 PM
Power2r's Avatar
Former Vendor
bump.............................,
Old Jul 11, 2009 | 08:54 AM
Power2r's Avatar
Former Vendor
to the top
Old Jul 13, 2009 | 03:05 PM
Power2r's Avatar
Former Vendor
This site moves way to fast. back to the top
Old Aug 9, 2009 | 01:11 PM
Power2r's Avatar
Former Vendor
back up front
gulliver64
Honda Civic (2006 - 2015)
Oct 30, 2018 09:42 AM
Turbo O
Nov 18, 2009 04:51 PM
Power2r
23
Aug 9, 2009 01:09 PM
egizzle8
Apr 7, 2005 07:37 AM
