Window Seal
Old Jul 12, 2007 | 06:47 PM
rebuiltSI's Avatar
Default Window Seal
Anyone know where I can buy a new OEM Window Seal, the rubber piece the window actually slides in between? This is for a 99 Civic Si. I did search, but wasnt able to find it.. maybe Im stupid.
Old Jul 12, 2007 | 07:08 PM
m00nr0ck Si's Avatar
Default Re: Window Seal (rebuiltSI)
http://www.hondapartsdeals.com
Old Jul 12, 2007 | 07:19 PM
rebuiltSI's Avatar
Default Re: Window Seal (dorkoftheyear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">http://www.hondapartsdeals.com</TD></TR></TABLE>
https://www.hondapartsdeals.co...B++53
Is #13 the Channel the rubber piece?
Old Jul 13, 2007 | 04:39 AM
WihaSi's Avatar
You are probably either talking about a belt molding or a run channel. If you are talking about a run channel then yes the part number on that site is #8 and #13.
Old Jul 13, 2007 | 05:07 PM
rebuiltSI's Avatar
Default Re: Window Seal (WihaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi &raquo;</TD></TR><TR><TD CLASS="quote">You are probably either talking about a belt molding or a run channel. If you are talking about a run channel then yes the part number on that site is #8 and #13.</TD></TR></TABLE>
Not sure of the difference between the belt molding and run channel, but what I do know is its the rubber piece the window actually has contact with while being rolled up. Its doesnt run along the bottom of the window opening along the door, only on the sides and top.
Old Jul 13, 2007 | 05:36 PM
WihaSi's Avatar
Yeah you're talking about the run channel, it is seated in the door frame. The belt molding or belt weather stip runs from the outside mirror to the applique on the outer panel of the door.
Old Jul 13, 2007 | 05:54 PM
rebuiltSI's Avatar
Hey its the run channel.. cuz its runs on the inside of the door frame where the window is.. It overlaps onto the edge of the window when the window is rolled up. Thanks guys
Old Jul 25, 2007 | 06:09 PM
rebuiltSI's Avatar
Just got the run channel in for my 99 Si and Im totally lost on the fitment. Anyone know if I have to trim the molding? If so why the hell would Honda make a part I have to trim. Visually it doesnt look like it fits, but what do I know. Ill take a picture of it laying on my floor.
Old Jul 25, 2007 | 11:52 PM
rebuiltSI's Avatar
CAUTION: NEVER REPLACE YOUR "RUN CHANNEL"!!!!!!!!!! That **** was way over my head and Im not sure how I even completed it. I did take short cut and didnt do it exact as the dealership would have, but it works and window rolls up nice and sit perfectly. It took me 4 1/2 hours because I have no mechanical experience. I went from thinking the "run channel" wouldnt even fit to learning the run channel went all the way down to the bottom of the window guide, then it had about an inch extra slack at the top curve part... anyways Im just writing this cuz im tired as expletive and amazed I pulled it off.
Good night
Mark
Jul 11, 2008 10:03 PM
tommy.
Sep 10, 2007 11:04 AM
CoolRedXylophone
Jul 29, 2006 07:31 AM
DFW
May 29, 2006 01:08 PM
dawrenn
Jun 20, 2005 02:40 PM
