Will this prevent rust?
Old Jan 15, 2010 | 02:58 PM
Jwbetley's Avatar
Default Will this prevent rust?
I have an idea. I have a 91 ef sedan. It has very little rust but it is starting to rust (as they all do) in the rear lower door jam quarter panel area. It seems to be rusting from the inside out.
If I put a grease fitting in the inner wheel well behind this area and pumped in say... 5 tubes of grease until it is completely packed with grease, would that prevent rust?
Old Jan 15, 2010 | 03:10 PM
ThePizzaMan's Avatar
Default Re: Will this prevent rust?
Uh, you need to remove the rust first.
Old Jan 15, 2010 | 03:38 PM
Jwbetley's Avatar
Why? Wouldn't the grease prevent further oxidation? Isn't grease a rust deterent like most oils? I just wanna know if this would work....
Old Jan 15, 2010 | 04:47 PM
milkmanLCA's Avatar
i dunno if this would work but ill tell you what will work.
wire wheel and some paint
Old Jan 16, 2010 | 12:58 AM
prelude1897's Avatar
grease won't cure rust. It's just going to get worse and worse. Nickname for rust in a body shop is "Cancer" you can't just throw something on it and expect it to disappear. It'll just spread and get worse, so you'll need to completely sand away the rust before fixing that area
Old Jan 16, 2010 | 06:38 PM
Hawkze_2.3's Avatar
That will absolutely not work
Old Jan 17, 2010 | 02:07 AM
ken9's Avatar
I think it would better to cut that piece and weld it. I think there a paint that can block the moisture from coming into the metal. Have anyone here try pro 15? Cutting and welding would be the best way to stop rust.
Old Jan 18, 2010 | 07:19 PM
AMseven's Avatar
POR 15 indeed..
Old Jan 18, 2010 | 07:27 PM
v8killaz's Avatar
wtf
thats thats a ****ed up idea, and how the hell did you come up with it
it obviously will dissapear after 1 mile drive time
Old Jan 18, 2010 | 10:32 PM
97ej6dx's Avatar
Patch Panels will solve your Ills
Old Jan 19, 2010 | 12:18 PM
hondaprofile's Avatar
New User
You need to remove the rust then use something like Rust bullet to prevent any spread. Grease will slow the spreading but the damage is already done.
4g4dcruisin
Paint and Body
Aug 6, 2010 08:57 PM
4DRmafia
Jun 17, 2008 08:33 AM
Masta
Paint and Body
Jun 15, 2008 08:48 AM
ludeitup
Paint and Body
May 26, 2008 11:29 AM
milkmanLCA
Paint and Body
Jul 1, 2007 09:16 AM
