is this strong enough?
Old Jun 13, 2007 | 01:23 AM
b_serious's Avatar
Default is this strong enough?
i was lookin at this compressor at the local store and wondering if it was strong enough to run a paint gun to paint my hatch?
and what was the exacty psi needed? i couldnt find it
http://www.harborfreight.com/c...94667
Old Jun 13, 2007 | 04:47 AM
exvelocity's Avatar
nope, you would run out of air, you'd need around 10 CFM @ 100 psi,
you may be able to spray one or twoparts at a time but not a complete car with that compressor
Old Jun 13, 2007 | 05:15 AM
b_serious's Avatar
Default Re: (exvelocity)
so this one would be better? would this work well with air tools? 1/2'' impact and stuff?
http://www.harborfreight.com/c...92504
Old Jun 13, 2007 | 06:00 AM
alltech_hybrid's Avatar
Default Re: (b_serious)
that one looks like it would work good but its a small tank
how bout this one?..
http://www.harborfreight.com/c...34887
Modified by alltech_hybrid at 9:10 AM 6/13/2007
Old Jun 13, 2007 | 06:39 AM
b_serious's Avatar
Default Re: (alltech_hybrid)
cool thanks for the info man, any does the size of the gun matter? or is there a special tip? i have some fenders and hood i wanna practice spraying on before i hit my car with any paint.
Old Jun 13, 2007 | 10:04 AM
boostedwagon's Avatar
that one needs 220v, but then again almost all of the bigger ones need 220
Old Jun 13, 2007 | 10:34 AM
b_serious's Avatar
Default Re: (boostedwagon)
whats 220v? im a noob to all this, but a quick learner
Old Jun 13, 2007 | 10:42 AM
110v is what normal household appliances run off of. 220v is what a clothes dryer runs off of. Also, be sure that the house has a big enough service line if you want to use that compressor. I bet it needs a 30A circuit. If your house only has a 100A service, you might be in trouble.
Old Jun 13, 2007 | 11:02 AM
exvelocity's Avatar
just go to Home Depot or Lowes, they usually have 50 gal 5hp compressors for $399 ,you will have to plug it in the dryer outlet at the house, it should work for you just fine,
Old Jun 13, 2007 | 11:42 AM
b_serious's Avatar
is there anyway to get another one of those dryer plugs installed in the garage?
Old Jun 13, 2007 | 12:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedwagon &raquo;</TD></TR><TR><TD CLASS="quote">110v is what normal household appliances run off of. 220v is what a clothes dryer runs off of. Also, be sure that the house has a big enough service line if you want to use that compressor. I bet it needs a 30A circuit. If your house only has a 100A service, you might be in trouble.</TD></TR></TABLE>
can anyone else who owns a compressor confirm this?
Old Jun 13, 2007 | 06:16 PM
JDM_DC4_Fanatic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exvelocity &raquo;</TD></TR><TR><TD CLASS="quote">nope, you would run out of air, you'd need around 10 CFM @ 100 psi,
you may be able to spray one or twoparts at a time but not a complete car with that compressor</TD></TR></TABLE>
WTF are you talking about? HVLP and LVLP spray guns all run between 20-40PSI, and they only need around 9-11SCFM of air flow. 10 cfm @ 100 is for impact guns and ****. I think you need to learn a bit more about compressors before you try to hand out advise.
The best kind of compressor to get for painting is a large tank (most gallons) and preferably a 2 stage compressor. However, the minimum requirements for most spray guns is 9 SCFM @ 35PSI as an average, so shoot for around that.
Old Jun 14, 2007 | 12:52 AM
b_serious's Avatar
Default Re: (JDM_DC4_Fanatic)
9@35psi so would this one work? http://www.harborfreight.com/c...92504
Old Jun 14, 2007 | 03:05 PM
yes, that compressor will work for your application.
Old Jun 15, 2007 | 04:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">yes, that compressor will work for your application.</TD></TR></TABLE>
do you think that tank is big enough for painting cars???
Old Jun 15, 2007 | 04:24 PM
kevinw's Avatar
Quote, originally posted by exvelocity »
Thanks you for correcting that i almost cried when i saw "spray guns use 100Psi", That be one screwed paint job.
Old Jun 15, 2007 | 09:05 PM
jakeiscool's Avatar
Banned
Default Re: is this strong enough? (b_serious)
people paint cars with air straight from compressors? i would never use anything but a downdraft booth and an air line with a moisture collector. prep and using the right tools could make an amateur painter look like a pro.
xbabysharkx
Paint and Body
Sep 9, 2008 09:16 PM
punkinbeck
Paint and Body
Aug 22, 2008 02:24 PM
rbeharry
Paint and Body
12
Apr 11, 2008 08:38 PM
92civicx
Paint and Body
Dec 27, 2007 12:55 PM
joblow
Mar 15, 2003 07:28 AM
