can i paint with this?
Old Dec 25, 2007 | 10:44 PM
92civicx's Avatar
Default can i paint with this?
i got a air compressor and i was just wondering if its good enough to paint on a car.
Its an 8 gallon tank,
4.5 scfm@40psi
13.7 scfm@80psi,
scfm @40 psi
125 psi max
and a gun that came with it and has a max inlet air presure of 50psig.
i don'tknow what any of these numbers mean, can anyone tell me if i can paint with this equipment? ............... thnx
Modified by 92civicx at 11:42 AM 12/26/2007
Old Dec 26, 2007 | 10:07 AM
92civicx's Avatar
Default Re: can i paint with this? (92civicx)
bump
Old Dec 26, 2007 | 11:58 AM
jasoncrashtech's Avatar
i wounldn' try it. you'll run out of air, then it will fill up, then you'll run out. smaller parts it would work but more spreying time needs a bigger compresser.
Old Dec 26, 2007 | 11:59 AM
Default Re: can i paint with this? (jasoncrashtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasoncrashtech &raquo;</TD></TR><TR><TD CLASS="quote">i wounldn' try it. you'll run out of air, then it will fill up, then you'll run out. smaller parts it would work but more spraying time needs a bigger compresser.</TD></TR></TABLE>
fixed
Old Dec 26, 2007 | 09:23 PM
92civicx's Avatar
ok so if i really wanted to paint a bumper i can do it,but it will just take time?
Old Dec 27, 2007 | 09:02 AM
welfarepc's Avatar
yep it will work. it wont work well, but it will work
make sure to get moisture filters. when your compressor is on more and more, it will create more and more moisture inside the tank, which shoots out your gun with your paint.
if you are a new painter you should be panting fairly slow anyways which will make the compressor seem more adequate.
my 6hp 25gal devilbiss is a bit small....
Old Dec 27, 2007 | 12:55 PM
92civicx's Avatar
Default Re: can i paint with this? (welfarepc)
aright thnx
eintsius
Oct 7, 2009 07:20 AM
D16SiHatch
Paint and Body
Jul 16, 2007 10:07 AM
pinoyboiwonder
Apr 5, 2006 10:33 PM
BrianDelSol
Apr 9, 2005 10:06 AM
joblow
Mar 15, 2003 07:28 AM
