Spray gun setting
Old Sep 27, 2007 | 08:58 AM
rex89sir2's Avatar
Default Spray gun setting
ok so im new to paint cars. I bought a hlvp spray gun for 100.00 bucks and i wanna spray my car but i wanted to know how to get the setting right on the gun and if i need to adjust my air compressor??
thanks for the help!
Old Sep 27, 2007 | 09:04 AM
rex89sir2's Avatar
Default Re: Spray gun setting (rex89sir2)
oh one more thing im wanting to paint my car a deep black what is a code for the color i went to the paint shop and eveything is sold by a code!
Old Sep 27, 2007 | 07:17 PM
Genuine Rolla's Avatar
Hit up google and you'll find out how to set the gun and what pressure you should use. Check out the paint shops paint chip books, find a black you want and tell them the code. Make sure the body work is perfect, black is a color that will show all the imperfections...!
Old Sep 27, 2007 | 09:32 PM
javijav's Avatar
Default Re: (Genuine Rolla)
in the back of the gun there should be 2 lil ***** to adjust it. on is for how wide it sprays the other is for how much comes out i believe. test it on a paper and check to see how wide it is.
Old Sep 28, 2007 | 06:41 AM
IP RACING's Avatar
Default Re: (javijav)
do you know how to paint
Old Sep 28, 2007 | 08:24 AM
alltech_hybrid's Avatar
Default Re: (IP RACING)
Depending on what type of gun you have you should have a few basic controls…
The fan control, used to adjust the size of the fan from tall to short, then you have control for the amount of paint and needle adjustment on the trigger
The main thing that I have learned that effects the proper spray pattern is the fan control and the correct air pressure… Practice on a sheet of masking paper before you even start spraying
What kinda compressor are you using? Some of those cheap $100 guns suk *****
Old Sep 28, 2007 | 11:24 AM
javijav's Avatar
im actually goin to school for it right now.....
Old Sep 28, 2007 | 11:48 AM
DC209's Avatar
not being a hater or nuthing but if you dont have painting skills its going to be hard to get it right black is one of the harder colors to paint but good luck and hope it looks good make sure your body work is perfect beccause if not it will show
Old Sep 28, 2007 | 02:19 PM
Pockets's Avatar
actually black is one of the easier colors to spray, you can easily hide any scratches and any dirt nibs wont show (like they would on white) and it covers the fastest
Old Sep 28, 2007 | 05:18 PM
Default Re: (Pockets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pockets &raquo;</TD></TR><TR><TD CLASS="quote">actually black is one of the easier colors to spray, you can easily hide any scratches and any dirt nibs wont show (like they would on white) and it covers the fastest</TD></TR></TABLE>
yeah but, if the body work isn't 100% straight...then you'll see it like none other. On white its harder to notice.
You don't have to worry about the dustnibs..thats what the wet sand and buff is for.
Old Sep 28, 2007 | 07:48 PM
rex89sir2's Avatar
thanks for all the info ive never used a spray gun to paint a car but i have a car that is kindda a test car so i wanna learn i hate paying people to do work on my car thats why i started working on them. Now i wanna learn to paint and then when i feel comfortable ill spray my b16 turbo crx.
thanks guys
Old Sep 30, 2007 | 03:07 PM
intrnsik's Avatar
Default Re: (alltech_hybrid)
How's it i'm interested in this subject, you people say to test it on paper or what not, what type of consistency should i be looking for when I'm testing it? How do I know when it is too much pressure or too little...what's my ideal? I know each brand specifys how much pressure to use but I'm curious what to look for. Any help is appretiated. Thanks.
Old Sep 30, 2007 | 09:13 PM
javijav's Avatar
Default Re: (intrnsik)
i guess u pretty much have to look on the paper or wat ever u test on. u dont want to adjust it to where its sprayin all over the place and jus dusting it. as long as its a good wet spray, then u should be fine. once u start sprayin, u wanna make sure u over lap it like 50%. example: if u spray the first line of ur hood, the next line should over lap it 50%. at least thats wat i do.
Old Oct 1, 2007 | 09:21 PM
intrnsik's Avatar
thanks for the input j planning to spray my brother's car soon hopefully...still working on the bodywork.
Old Oct 3, 2007 | 04:27 AM
what you look for is a verticle even line pattern... test it on the paper until you get a tall even line... if its not adjusted properly the gun will shoot an "8" pattern or too much paint on the top and bottom and less in the middle.. or vise versa. you want it all even so it lays down with a nice even fan of paint. the wider the fan spray the better
good luck!
Old Oct 3, 2007 | 01:28 PM
blue2000em1's Avatar
Here's how to adjust your settings
To test the gun:make sure the Fluid needle is all the way screwed in.(screw material valve all the way in)counter clockwise.Come back out 3 1/2 full turns back out.Applies for (base or clear).Now open your fan spray all the way up go 1 1/4 turning in,remember to adjust your air pressure cordingly.(this is how to test or set a gun)
Old Oct 3, 2007 | 04:31 PM
powerflow's Avatar
Default Re: (blue2000em1)
Wtf, most fan control ***** only rotate just around 360 deg. That makes no sense to rotate back 1 1/4. There is really no one way to set up a gun. It relates mostly to the style or technique used by the painter.
OP, it depends on what type of comp your using. Also if how fast you spray, overlap, distance from cap to surface, ect. There is a ton of info on the net about this.
Old Oct 3, 2007 | 07:10 PM
Default Re: (powerflow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerflow &raquo;</TD></TR><TR><TD CLASS="quote">Wtf, most fan control ***** only rotate just around 360 deg. That makes no sense to rotate back 1 1/4. There is really no one way to set up a gun. It relates mostly to the style or technique used by the painter.
OP, it depends on what type of comp your using. Also if how fast you spray, overlap, distance from cap to surface, ect. There is a ton of info on the net about this. </TD></TR></TABLE>
your attitude stinks
Old Oct 4, 2007 | 05:49 PM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue2000em1 &raquo;</TD></TR><TR><TD CLASS="quote">
your attitude stinks </TD></TR></TABLE>
but everything he said is true. sad but yea true
Old Oct 4, 2007 | 06:09 PM
Default Re: (2'z kuztoms)
yeah he has a point but I'am telling you how I-car teaches it for people getting behind a HVLP and a RP.
matek33
Jul 5, 2016 02:59 AM
Nations Sickest CRX
Sep 21, 2009 12:00 AM
drumminforev
Jan 27, 2006 08:07 AM
titan2nv
Apr 13, 2005 11:02 PM
WuShu
Apr 17, 2001 04:32 PM
