Should I fix or replace my subframe?
Old Feb 24, 2008 | 08:17 AM
blue_hatch's Avatar
Default Should I fix or replace my subframe?
Heres what Im working with. Should I just replace the lca part, or replace the entire subframe?
Old Feb 25, 2008 | 07:57 AM
hawjboi's Avatar
Default Re: Should I fix or replace my subframe? (blue_hatch)
if that right side is welded on then i myself would personally change the whole frame imo...
Old Feb 25, 2008 | 04:01 PM
HONDAPARTSMANMIKE's Avatar
i would replace the subframe. what happened to it???
Old Feb 26, 2008 | 02:54 AM
Disease's Avatar
Default Re: Should I fix or replace my subframe? (HONDAPARTSMANMIKE)
I don't really know what I am looking at. Looks like you took off all the undercoating on the right side and maybe it was sectioned before. If it has a good wheel alignment, I would not even go through all that trouble. Just make sure that it is welded on right and put some rustproofing on it.
On a side note is your spare caved in?
Old Feb 26, 2008 | 06:25 AM
blue_hatch's Avatar
Default Re: Should I fix or replace my subframe? (Disease)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disease &raquo;</TD></TR><TR><TD CLASS="quote">I don't really know what I am looking at. Looks like you took off all the undercoating on the right side and maybe it was sectioned before. If it has a good wheel alignment, I would not even go through all that trouble. Just make sure that it is welded on right and put some rustproofing on it.
On a side note is your spare caved in?</TD></TR></TABLE>
the right side was damage and the previous owner welded a ek bracket to it. Im just going to fing me a eg bracket and weld it in
Old Feb 26, 2008 | 12:50 PM
Disease's Avatar
Why would they put an ek bracket on there LOL. Go through all that trouble. I would not put a whole new subframe on there I would just put that section on. Doing the whole thing will just be asking for problems. If the left side is fine and in spec then I would just put that one corner on. You should be able to find a frame chart for an eg on HT somewhere I think.
Old Feb 26, 2008 | 05:15 PM
blue_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disease &raquo;</TD></TR><TR><TD CLASS="quote">Why would they put an ek bracket on there LOL. Go through all that trouble. I would not put a whole new subframe on there I would just put that section on. Doing the whole thing will just be asking for problems. If the left side is fine and in spec then I would just put that one corner on. You should be able to find a frame chart for an eg on HT somewhere I think. </TD></TR></TABLE>
yeah the guy I bought the car had no clue about civics but for doing a haf-*** job. Im going to the junkyard and cut me out the replacement section sometime next week
Old Feb 26, 2008 | 08:15 PM
KNS Autosport's Avatar
I had a customer with a simmilier issue on a 92 Civic Hatch, I found the part at the dealer for only $120. You might want to look into that, it saved me quite a bit of work and time
Old Feb 27, 2008 | 05:56 PM
blue_hatch's Avatar
Default Re: Should I fix or replace my subframe? (KNS Autosport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KNS Autosport &raquo;</TD></TR><TR><TD CLASS="quote">I had a customer with a simmilier issue on a 92 Civic Hatch, I found the part at the dealer for only $120. You might want to look into that, it saved me quite a bit of work and time</TD></TR></TABLE>
Its $170 from majestic auto parts
Old Feb 27, 2008 | 11:50 PM
Ep1dem1c's Avatar
new car... doesnt look safe
Old Feb 28, 2008 | 01:12 PM
what year, model etc ?
Old Feb 28, 2008 | 06:04 PM
90goldhatch's Avatar
are u serious, get another one
shaunk18
Nov 27, 2007 05:15 PM
pjr710
10
Jul 4, 2007 06:29 PM
Terrible One
Jun 1, 2006 09:14 PM
integrator43
Honda Motorcycles
15
Nov 27, 2005 04:34 PM
peshte
Nov 15, 2004 11:26 AM
