Scrathced Taillight - Fixable?
Old Nov 7, 2011 | 04:52 PM
Rogue's Avatar
Default Scrathced Taillight - Fixable?
I just picked up an eg hatch and it had a busted taillights. I found some cheap JDM tails that had some deep scratches and was wondering if it is fixable.
Old Nov 7, 2011 | 05:08 PM
joeshmo's Avatar
Default Re: Scrathced Taillight - Fixable?
It looks pretty serious to me. At best, I think you could reduce the scratches. Kindof hard to gauge with just pictures though. Start sanding, 400 grit wet. Check your work often. I suggest taping off the un-damaged area.
Old Nov 7, 2011 | 05:17 PM
Hawkze_2.3's Avatar
You should be able to block sand those and shoot some clear on them...depending on how deep the scratches are.
Old Nov 13, 2011 | 05:38 PM
brianb242's Avatar
treat it like you do any other painted part start out with 400 grit, then go to 600 grit wet, then to 800 grit, 1000 grit wet, once you get to that point 3M makes two compounds to bring the shine up. if it's too much for you to handle send me a pm I can make them look like new. or I can sell you another tail light <<<cheaper in the long run.
Old Nov 13, 2011 | 05:39 PM
joeshmo's Avatar
I rarely start with 400 grit on painted parts.
Old Nov 13, 2011 | 05:44 PM
Rogue's Avatar
I would say from a scale of 1 to 10 I am a one with paint and body work. Mechanics would be a 9.
You have a spare JDM tail?
Old Nov 14, 2011 | 12:46 PM
Mu9enx's Avatar
+1.
You don't even have to do all that sanding. As long as you sand off most of the crap, you can just use 1000+ grit for the job. Then do some compounding on it till it starts to shine.
Plast-X might work wonders too.
Old Nov 14, 2011 | 12:48 PM
Rogue's Avatar
yea.. lol.. i guess i may have to venture out and see... I have the old lights i could practice on.
Old Nov 14, 2011 | 12:53 PM
Mu9enx's Avatar
It's not too hard, it looks pretty salvageable. Just make sure you take your time, and PLEASE wet sand. You should start with a 1000 grit to see if it helps, and if not, get rougher and lower it to 800 grit. After most of the gunk is gone, just take a polisher (or if you're a thug, by hand) and compound it. After that you can apply some wax or sealant (cuz you're basically removing the clearcoat) and it should look a lot better.
Old Nov 18, 2011 | 01:49 PM
CrowHatch's Avatar
Sand like mentioned above. Reclearing is the best way to seal and protect. I know you can buy catalyzed clearcoat in an aerosol can. You should be able to pick one up from an autobody supplier.
Old Nov 24, 2011 | 02:56 PM
Fibercation's Avatar
from the pics id do the scratch areas with 220 then 400 then sand entire light and clear coat out of a spray gun ppg clear. wet or dry sand wont matter if u clear out of a gun....better and faster than trying to sand/polish out
drewrund
Paint and Body
Nov 30, 2011 07:57 PM
JDM_SOHC
Paint and Body
Jun 22, 2010 10:17 AM
PolishSasquatch
Paint and Body
Jul 23, 2009 10:16 AM
g4hatchie
45
Nov 4, 2003 03:38 PM
VXpride
Jun 16, 2002 11:03 AM
