SANDING PRIMER QUESTION!
Old Jul 17, 2009 | 04:29 PM
roadsqueegy95's Avatar
Default SANDING PRIMER QUESTION!
Hello guys and gals!!
Got a noob question, ive read the sticky at top of the paint thread, but still alil confused. I finished spraying my first coat of 2k urathane primer lastnight. should i wet sand it tonight? or spray another coat? i was thinking of wet sanding inbetween coats with 400 grit and sand the final coat with 600 grit?
Thanks,
Justin
Old Jul 19, 2009 | 05:42 PM
Eyger's Avatar
Default Re: SANDING PRIMER QUESTION!
That sounds good to me. I'm sanding my first coat with 320 wet, then I'm going to go over it again with another coat of 2k, then sand it with 600 and then seal it, then paint it.
Old Jul 20, 2009 | 11:52 AM
ya thats what i did this weekend, seems to have worked good, but i broke thro to the etching primer on the edges of the panels, o well ill just have to reprime them and be real careful! lol
Old Jul 21, 2009 | 05:17 PM
prelude1897's Avatar
IMO, if you're wet sanding between coats, you're just wasting time. Spray 3-4 layers of 2k primer or how ever much you need to cover the area, then dry sand to smooth out any dry spots or runs. I normally use 180 grit. If you see any pin holes/solvent poppings, then spray another layer on which should fill in those holes. Then once again dry sand again, then wet sand. After you're done wet sanding, clean it up and it'll be ready to spray.
94civiccpe
Paint and Body
Jul 17, 2013 07:52 PM
JDMCRX
Paint and Body
Jul 17, 2011 08:45 PM
htsang07
Paint and Body
Jun 11, 2010 04:11 AM
PolishSasquatch
Paint and Body
10
Jun 12, 2009 02:40 PM
