rust stopper?
Old Jul 2, 2007 | 09:24 AM
Paprika's Avatar
Default rust stopper?
This is probably a strange or maybe even "Stupid" question, but...
I have bad rust spot forming over my rear wheel wells, I tried sanding away the rust and priming them but the rust grew back and ate through the primer basically.. I've been busy with school and have not had time to see to these things, and would like to try to do something about the unsightly spots when I go home this weekend.
Are there any paste or chemical products that I can apply to stop the rust in some way? Is there anything I can do short of grinding down the metal till all the rust is gone? I'm afraid it may be kinda deep at this point
Thank you for your time and not flaming me because I did attempt to search.
Old Jul 2, 2007 | 09:35 AM
jdmdc10's Avatar
i have the same problem, all i do is spray rust preventer on it. You might be in too deep, you might have to cut it all out then weld some metal in there. Just thinking. I heard of this chemical that you spray on rust and it makes a reaction to get rid of the rust or something.
but bump for some more ideas.
Old Jul 2, 2007 | 06:22 PM
Paprika's Avatar
Thanks for the reply mate!
bump for more ideas to help us Ohioans.
Old Jul 2, 2007 | 06:59 PM
instructor74's Avatar
Default Re: (Paprika)
Really the only way to get rid of the rust is to cut it out and replace it with new metal
Old Jul 2, 2007 | 07:00 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (instructor74)
http://www.rustbullet.com/Prod...aTech
Old Jul 3, 2007 | 07:05 AM
jdmdc10's Avatar
Default Re: (ek forever guy)
What if its eating through though? You might still have to cut it out and weld.
Old Jul 3, 2007 | 07:58 AM
Ek Forever y0!
Default Re: (jdmdc10)
Yes, Though if it's just surface rust, rust bullet does wonders.
Even if you neglect deeper rust, rust bullet is supposed to seal.
Old Jul 3, 2007 | 09:55 AM
chitownrida's Avatar
lookup rust bullet
por 15
many to list.. called "rust encapsulation"
Old Jul 3, 2007 | 10:09 AM
Ek Forever y0!
Default Re: (chitownrida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitownrida &raquo;</TD></TR><TR><TD CLASS="quote">lookup rust bullet</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.rustbullet.com/Prod...aTech</TD></TR></TABLE>
Posted it yesterday.
Old Jul 3, 2007 | 12:40 PM
Ice-Nine's Avatar
My car that I'm redoing has some rust spots as well. What I did was sand blast the area that the rust is working on. Then I sprayed some rust converter on it. I then sprayed primer on it. Eventually I will put bondo in where it ate through and the deeper spots and then prime it again. So far on what I did it has worked great.
Old Jul 3, 2007 | 01:54 PM
SL!M's Avatar
Nothing stops rust. Nothing. If its weakening the metal you need to cut out the panels and weld in new ones. Im currently in the process. PM me if you want some pictures. Its very very time consuming.
Old Jul 3, 2007 | 05:35 PM
sc4dr's Avatar
Default Re: (SL!M)
Rust on outer panels must be cut out. Having to many coatings with conflicting makeups will only lift or blister the paint later down the road. I've found that por 15 works the best for rust on frames/floors/non-exterior panels etc.
Old Jul 3, 2007 | 07:28 PM
Paprika's Avatar
i was kinda lookin for somethin i could pick up in a local store sometime soon. this car is urkin me right now, I'm glad it's still runnin, it just could look a bit better
Old Jul 4, 2007 | 10:05 AM
Paprika's Avatar
oops to the top for some quick answerz
Old Jul 4, 2007 | 11:39 AM
milkmanLCA's Avatar
por 15 works great, i just did it like a week ago. strong ****
Old Jul 4, 2007 | 02:38 PM
Paprika's Avatar
Default Re: (milkmanLCA)
is por 15 only avalible online?
Old Jul 5, 2007 | 06:01 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika &raquo;</TD></TR><TR><TD CLASS="quote">is por 15 only avalible online?</TD></TR></TABLE>
Yes. http://www.por15.com/
Old Jul 5, 2007 | 08:47 AM
milkmanLCA's Avatar
thats where i got it from, fast shipping too. get the starter kit, you dont need alot. and wear the gloves. **** stains
4g4dcruisin
Paint and Body
Aug 6, 2010 08:57 PM
HiyahBeech!
14
Aug 22, 2007 07:58 PM
abnaasefmb
21
Jul 9, 2005 07:59 PM
4runner
Jun 7, 2005 03:21 PM
4doorH22
Aug 10, 2002 01:17 PM
