Repainting lip. Need prep help
Old Sep 28, 2007 | 02:15 PM
SmellySOHC's Avatar
Default Repainting lip. Need prep help
ok so basically what i need to do is only prep the lip and a friend mine will be painting it.. so the deal is, what do i use to remove the prior paint, what grit do i sand with, and what do i use as a flexible primer/adhesive? also, how do i remove scuffs from the previous owner bottoming out??? any help would be greatly appreciated....BTW its a oem 00 si lip
Old Sep 28, 2007 | 03:42 PM
SmellySOHC's Avatar
Default Re: Repainting lip. Need prep help (SmellySOHC)
anyone?
Old Sep 29, 2007 | 06:32 PM
SmellySOHC's Avatar
anyone?
Old Sep 29, 2007 | 08:36 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmellySOHC &raquo;</TD></TR><TR><TD CLASS="quote">ok so basically what i need to do is only prep the lip and a friend mine will be painting it.. so the deal is, what do i use to remove the prior paint, what grit do i sand with, and what do i use as a flexible primer/adhesive? also, how do i remove scuffs from the previous owner bottoming out??? any help would be greatly appreciated....BTW its a oem 00 si lip </TD></TR></TABLE>
so it's an ABS lip? how bad is the damage? if it's really bad you have to sand it all down to bare material.
if it's just some minor scruff, just sand it with 220 sand paper, rub up all the paint with a hatch strokes.
you DONT need flex agent if you are not sanding it down all the way, btw you only add flex agent to the primer(which you dont need to remove if the lip is not totally toasted) and the clear Coat.
onmi's clear is very flexible, i doubt you need to add flex to it if you are using that.
Old Sep 29, 2007 | 08:41 PM
SmellySOHC's Avatar
Default Re: Repainting lip. Need prep help (iam7head)
well its going to be repainted a completely different color so i have to strip it anyway..its only scraped from bottoming out
Old Sep 29, 2007 | 08:47 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SmellySOHC &raquo;</TD></TR><TR><TD CLASS="quote">well its going to be repainted a completely different color so i have to strip it anyway..its only scraped from bottoming out</TD></TR></TABLE>
um...you don't need to stripe it down to bare material even if you are painting it to a totally different colour, damaged lip or not.
the reason for "sanding" the clear coat is to get the coat to stick(think of cleaning a stain off smooth leather instead of rugged cotton, the smooth surface will have much lesser "stick" to it)
Old Sep 29, 2007 | 09:43 PM
SmellySOHC's Avatar
gotcha...but the paint is all cracked and crap..i can basically peel the paint off with my nail
Old Sep 29, 2007 | 10:23 PM
iam7head's Avatar
have fun
Old Sep 30, 2007 | 07:08 PM
SmellySOHC's Avatar
haha thanks for the help up until that useless comment...jk,...any one else?
Old Oct 1, 2007 | 10:01 AM
SmellySOHC's Avatar
haha bump...anyone?
Old Oct 1, 2007 | 11:50 AM
talontsiawd's Avatar
If your lip is urathane, look into Sems urathane bumper stripper. It should do the job without damaging the urathane.
I however have an abs lip. I tried that stuff and it damaged it (not to the point where i had to trash it). So if refinished it accouple times. How i did it was start with 150 grit or so sand paper and moved down to 600. You don't need to get to the base surface but with any cracks, chips, spider webbing, etc, you want to sand that all the way down.
After sanding, i use high build filler primmer. Then sand that totally smooth with 600 grit. Then use color match spray paint and clear. Works pretty well.
Old Oct 1, 2007 | 06:13 PM
SmellySOHC's Avatar
thanks bro...thats what i was lookin for...oem lip is urethane right?
Old Oct 1, 2007 | 06:15 PM
Default Re: (SmellySOHC)
Yes, it should be urathane.
Old Oct 2, 2007 | 07:21 PM
SmellySOHC's Avatar
bump.... anyone else?
Mr. EJ1
Aug 15, 2008 02:29 PM
FrostyDC4
Mar 28, 2005 05:26 PM
baphomet
Sep 22, 2003 04:13 PM
