Removing remaining residue from sound deadening material.
I used dry ice to remove sound deadening material from my car. Some parts came off perfectly while other parts not so nicely. Using primitive tools (I don't have power tools), how would I remove this gunk? I will not be repainting the interior of my car, I just want this gunk removed.
Any help is appreciated!
Re: (RedneckRicer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedneckRicer »</TD></TR><TR><TD CLASS="quote">kerosene.. just like roofing tar ***** impossible to get off your skin and kerosene is only the real way to get it ALL</TD></TR></TABLE>
Thank you! This is my first time doing anything regarding paint -_-
Would I apply it and let it soak?
Re: (time attack)
Just remember that kerosene is EXTREMELY flammable, dont smoke wile working with it, and keep it away from any open flames as the vapors can explode.
Re: (LastDetail)
A painter friend of mine gave me this stuff called Goop Off or something close to that. I will try to post pictures later once I get more cleaned off. It's working very well!
The product is water-based (like soap) and non-toxic
Re: Removing remaining residue from sound deadening material. (time attack)
Paint stripper works great,
i use it for everything
from degreasing motors to cleaning floorpans
spray can form is alot eaiser to use but the goopy tubs work well too, jus be sure to wear gloves and a mask...harmful vapors and skin irritant....
gl man...
my pass side done using paint stripper
Modified by 99vSmEj8 at 12:48 PM 5/12/2008
gl man...
Re: Removing remaining residue from sound deadening material. (99vSmEj8)
after you removed the paint with the paint stripper did you prime it or paint it afterwards?
I used brake parts cleaner and a rag, just be sure to leave your doors open so you don't pass out from the fumes. **** kills your head.
aesthetics82
34
05-10-2004 07:52 PM
