Remove logos?
Old Apr 21, 2007 | 10:36 AM
HOUSTONb's Avatar
Default Remove logos?
Tried a few searches and nothing. How can I remove the civic and ex logos from my trunk? Also what about pin stripes?
Thanks guys/gals
Old Apr 21, 2007 | 10:48 AM
Single Cam Slam's Avatar
Default Re: Remove logos? (HOUSTONb)
Use a heat gun or hair dryer to heat up the glue. Then use a putty with duct tape on the end. Move the putty knife slowley to make sure you don't scrape off the paint underneath the badge. After you remove the badges clean off the excess glue with bug and tar remover. Then use the heat gun to soften any stubborn deposits of glue.Wipe off the ares thoroughly with a soft cloth. Ant then use car wax to remove any oxidation and to seal the paint.
Old Apr 21, 2007 | 11:09 AM
TheWhiteHatchProject's Avatar
Default Re: Remove logos? (Single Cam Slam)
i dont know about using a putty knife but using a heat gun works very well. behind your emblems are two sided adhesive. you can heat the adhesive up and it will come off alot easier than trying to pull it off otherwise. do not apply direct heat to the area...sweep back and forth. in the past ive used dental floss and a heat gun. be aware that some emblems have guide plugs (those holes behind the honda H) because they are used as guides in the assembly process.
heat gun or a rubber eraser that attaches to the end of a drill (yes there is such a device) will work for pin striping
hope this helps
Old Apr 21, 2007 | 01:13 PM
John M's Avatar
Default Re: Remove logos? (TheWhiteHatchProject)
i used a heatgun and some time. worked great and plus it helped cause it was a really hot day.
Old Apr 21, 2007 | 03:02 PM
itekdu's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheWhiteHatchProject &raquo;</TD></TR><TR><TD CLASS="quote">rubber eraser that attaches to the end of a drill (yes there is such a device)</TD></TR></TABLE>
Called a caramel wheel?
Old May 1, 2007 | 11:12 PM
Default Re: Remove logos? (itekdu)
not sure if ive ever heard it called that but any auto paint supply company will know what youre referring to
VTEC_PRODUCTION
Paint and Body
Aug 10, 2007 09:50 PM
UA6 BALLER STATUS
Nov 30, 2004 12:08 AM
iam7head
Sep 25, 2002 07:05 AM
95civiccoupe31
13
May 29, 2002 06:38 AM
IntegraZ
Apr 22, 2002 09:33 PM
