reclearing?
Old Apr 27, 2011 | 03:58 PM
dc4teg95's Avatar
Default reclearing?
I recently sprayed my fenders and after laying the clear it doesn't look as good as the other parts I painted and was going to reclear them. What grit do I use to scuff it with?
Old Apr 27, 2011 | 04:37 PM
(. )( .)'s Avatar
Default Re: reclearing?
apply another coat of clear, let it dry for an our or 2, apply about 3 layers just to be safe. use 1000 grit wet sanding paper to knock off the orange Peel. follow by compound, Polish. wait 1 month to wax.
Old Apr 27, 2011 | 04:56 PM
dc4teg95's Avatar
So do I wet sand it smooth with 1000 grit then respray the clear?
Old Apr 27, 2011 | 06:24 PM
prelude1897's Avatar
wet sanding with 1000 grit will work perfectly fine and then reclear it
Old Apr 28, 2011 | 07:03 AM
(. )( .)'s Avatar
i have recleared 3 coats and wet sanded after all 3 have been applied, without any issues and had it fully dry looking wet and glossy after.
you CAN wet sand in between coats just make sure you fully clean the surface before applying the next coat.
Old Apr 28, 2011 | 06:51 PM
gorillafart's Avatar
you mean let the clear completely harden and then wetsand and shoot another coat?
thats too much work
Old Apr 28, 2011 | 08:27 PM
(. )( .)'s Avatar
thats too much work
correct. let it fully dry> wet sand>clean>dry>apply next coat…repeat.
sh!ft
Paint and Body
10
Sep 15, 2009 12:02 AM
akces
Paint and Body
Apr 4, 2008 04:45 PM
joseesp
Paint and Body
Mar 6, 2008 12:37 PM
1.8
Nov 28, 2004 11:24 AM
ShakesTheKlown
Jul 4, 2003 01:35 AM
