orange peel
Old Apr 1, 2008 | 08:04 PM
akces's Avatar
Default orange peel
whats the definition of it or what is it..thanx for the info
Old Apr 1, 2008 | 08:35 PM
suno's Avatar
After you spray the paint and on the surface the paint starts to bubble. The bubbles look like the peel of an orange.
Old Apr 2, 2008 | 12:53 AM
gripunitEK9's Avatar
Default Re: (suno)
orange peel is what happens on a surface when not enough or uneven coverage of clear coat. some orange peel could look dry (not enough clear) and some look really rough and wet looking usually meaning too much clear sprayed from a further distance and not enough cure time(flash) time in between coats. orange can be remedied by wet sanding then buffing. when applying clear be sure to clean the surface well and make consistent controlled passes making sure to mind your wet edge.... good luck!!
Old Apr 2, 2008 | 12:56 AM
Default Re: (suno)
btw... paint does not cause orange peel.... paint does not "bubble"..... improper use and spraying of clear will cause orange peel....
Old Apr 4, 2008 | 04:45 PM
akces's Avatar
Default Re: orange peel (akces)
thank you fellas
ZC DOHC CRX
Paint and Body
Mar 31, 2009 09:18 PM
drumminforev
Dec 8, 2006 10:10 AM
- BSeRiouS -
Jul 1, 2005 11:07 PM
Ef Whore
Nov 29, 2002 08:03 AM
