quick question about bodyfilling
Old Aug 21, 2007 | 12:06 AM
ar3dd's Avatar
Default quick question about bodyfilling
Ok the rust on my DA is bubbling should i sand it down back to surface level and then put on bodyfiling then sand and what not or does bodyfilling go first? im a noob at this but i can go any further on this project before getting this done so someone please help me out ill ry and get pix tomorrow to see what im talking about
Old Aug 21, 2007 | 12:54 AM
lazeballz's Avatar
Default Re: quick question about bodyfilling (ar3dd)
generally rust doesnt just appear on that one spot. You want to sand around it..maybe 4-5 inches around it just to make sure you eliminate all the rust (dont forget behind it. - if it has rust all the way through). Once you have done this, you'll want to fix the area with body filler to regain your surface. once this is complete you will want to apply an etching and sealing primer above the baremetal and bondo. Allow this to dry, then paint.
hope that helps
Old Aug 23, 2007 | 06:37 PM
speedworks's Avatar
Default Re: quick question about bodyfilling (lazeballz)
if you just sand and refill the rust with bodyfiller it will just come back. it will have to be cut out and a metal patch welded in to fix it correctly.
purpleandgreen
Apr 2, 2007 07:23 PM
totsie7944
Jul 29, 2006 02:47 PM
deconstruct
Jul 21, 2005 10:40 PM
94si94cx
Nov 14, 2002 06:50 PM
Attoir
Aug 25, 2002 07:10 PM
