primer needed when respraying same color?
Old Jun 21, 2007 | 06:48 PM
msinsky14's Avatar
Default primer needed when respraying same color?
just wondering if i need to prime the entire car if just respraying outside same color (rio red). should i just scuff the paint with 320 grit wetsand?
Old Jun 21, 2007 | 06:56 PM
msinsky14's Avatar
Default Re: primer needed when respraying same color? (msinsky14)
oh yea, and what air gun will work with an 8.2cfm @40PSI COMPRESSOR WITH 4.5HP?
Old Jun 21, 2007 | 07:48 PM
SneezinCD5's Avatar
Noprimer is needed if you don't do any bodywork. As far as a gun, look around at the HVLP's. You should have a couple brands to choose from.
Old Jun 21, 2007 | 07:54 PM
tattooedsmoke's Avatar
Peimer is only needed if you did body work or want to fill feather scratchs and hvlp gun needs 10 lbs at the cap your compresser will not keep up .. your clear will have bad texter
Old Jun 22, 2007 | 04:03 PM
BoogieDownBrown's Avatar
Default Re: primer needed when respraying same color? (tattooedsmoke)
You would also want to primer it if you break through the clear. You can either seal it and spray wet on wet or prime,block then paint.
Old Jun 29, 2007 | 01:30 PM
msinsky14's Avatar
Default Re: primer needed when respraying same color? (BoogieDownBrown)
what grit wetsand paper should i use to scuff the paint?
Old Jun 29, 2007 | 01:33 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">what grit wetsand paper should i use to scuff the paint?</TD></TR></TABLE>
400 if your shooting base.
Old Jun 29, 2007 | 01:37 PM
powerflow's Avatar
Basically, solid colors around 500-600 metallics around 800-1000
O16581724 5 2 5
Oct 12, 2005 11:22 PM
xcellorator
Apr 26, 2005 03:37 AM
nel1
Welding / Fabrication
Mar 22, 2005 09:16 PM
Dc2 Powered
Mar 6, 2005 09:23 PM
kefka
16
Apr 10, 2003 03:23 PM
