Primer before Base/Clear?
Old Aug 11, 2009 | 07:12 PM
be18see1's Avatar
Default Primer before Base/Clear?
So I just finished sanding off all the flat black spray paint off my project Integra and am now left with the stock white paint minus the clear coat. Everywhere that I filled in dings and sanded to the bare metal I primed over with self-etching primer. I then sanded the whole care with 400 grit. Here's the question:
Do I need to prime the entire car? Some people have said that it's essential while others have said that the factory base will provide a good surface for the paint to adhere to. I will be spraying a urethane (I think) base/clear and I have already sprayed the bay and jams with a urethane single stage. Thanks!
Old Aug 11, 2009 | 09:50 PM
prelude1897's Avatar
Default Re: Primer before Base/Clear?
no you don't need to primer the whole car. The base coat will act as a primer. The only thing you need to primer are parts where you use body filler or where there's bare metal. Be sure to use 2k urethane primer and don't forget to dry sand, then wet sand the area you sprayed the primer onto. I normally use 180 dry, then 400-600 wet
Old Aug 12, 2009 | 11:23 AM
be18see1's Avatar
Okay, thanks a lot bud! I appreciate your help.
sh!ft
Paint and Body
11
Jul 22, 2010 04:19 PM
htsang07
Paint and Body
Jun 11, 2010 04:11 AM
CPreston
Paint and Body
Apr 25, 2009 06:15 PM
f22 lx
Jun 2, 2005 04:53 PM
self_made
Sep 19, 2002 10:47 AM
