Prepping help??
Old May 20, 2007 | 12:52 AM
Smallpox33's Avatar
Default Prepping help??
My car has 2 coats of paint on it, with the second layed over the stock paint, ive gotten everything down to a flat surface with 400 grit and i have primed the car.
should i now go over it with 800 wet and re prime then 1000 wet and paint?
Old May 20, 2007 | 08:34 AM
WihaSi's Avatar
Default Re: Prepping help?? (Smallpox33)
Did you prime it with a sealer or a filler primer? If you just put down a regular sealer primer you can just go over it with a scuff pad (or even 1000 grit). If you put down a primer filler then I would suggest wet sanding with 600 or 800 (I prefer 800), then wash it off, dry it, then spray it with a sealer primer, after that dries do BC/CC.
Old May 20, 2007 | 09:03 AM
Smallpox33's Avatar
Default Re: Prepping help?? (WihaSi)
i used a filler primer, thanks for the advice!
VegasEg8
Paint and Body
Sep 11, 2014 09:30 PM
bluenc-87
Paint and Body
Jul 19, 2009 06:31 PM
masijdm
Paint and Body
Feb 24, 2009 11:09 AM
old_school_dohcvtec
Paint and Body
Sep 22, 2008 09:46 PM
