painting question... help...
Old Dec 31, 2007 | 09:33 PM
Civic-Kids's Avatar
Default painting question... help...
when u layout down couple coat of base... some spot are glossy n some not (rough surface)... if i going to clear it. do i need to wet sand the rough surface or it ok to clear over it? help plz...
Old Jan 1, 2008 | 01:54 AM
iam7head's Avatar
Default Re: painting question... help... (Civic-Kids)
there shouldn't be any "glossy" basecoat at all after it's dry.
if you have some uneven paint build up(or dust or runs) you need to sand it out
before laying down the clear. the catches are you have to laid down another coat
of base to cover the sand scratches
Old Jan 3, 2008 | 05:26 PM
MiracleWhip's Avatar
during the base coat operation, i feel that it is ok to wetsand the base after it has thoroughly flashed over- not still wet. the appropriate grit sandpaper should be used. i'd go with a the 1500 grit/wet. sand until smooth and recoat your base. also make sure your substrate (panel) is clean and dry.
it sounds to me that the roughness of base maybe due to a clogged air cap, innsuficient overlaps or maybe too low of air pressure. before you spray something, test it out on a piece of cardboard or masking paper to check the spray pattern. that way, you'll know not to continue and waste time and money. holler at me.
roadsqueegy95
Paint and Body
Jul 21, 2009 05:17 PM
thw_goalie
Paint and Body
Sep 2, 2008 02:17 PM
kelviiv
Paint and Body
Mar 18, 2008 06:28 PM
R,coustoms
Paint and Body
Dec 31, 2007 04:58 AM
dxhatch93
Sep 24, 2005 11:51 PM
