Need Major Help!!
Old Mar 18, 2008 | 04:37 PM
kelviiv's Avatar
Default Need Major Help!!
I am trying to paint my fender and front end but I can't even get base coat down smooth!
I tried 3 times already and I am about to give up :[
I messed around with the psi setting and still no luck.
I am using a 50 gal air compressor.
shooting bc/cc omni ppg.
LMK if you have any suggestions
thanks to iam7head & powerflow
Old Mar 18, 2008 | 04:55 PM
powerflow's Avatar
Default Re: Need Major Help!! (kelviiv)
What temp reducer are you using? The atomized paint micro-droplets could be drying to fast, beginning to dry in the air before applied to the panel. Also your conditions may allow the over spray to settle on the surface resulting in a rough feel. Have you tried tacking between coats to removed settled dust? Does it seem like its flashing off too fast?
Did you correctly mix to the recommended ratio?
What gun are you using and what size.? Did you test the spray pattern?
Have you tried different material settings along with the different air pressure? If its a rough, dry, too thin coat texture/feel, could be too much air, gun distance too far, paint too thin, stroke too fast, fluid control not opened up enough.
Or is it an excessive peel from what I maybe mentioned before?
Old Mar 18, 2008 | 05:00 PM
kelviiv's Avatar
yeh i was able to get 2 coats off that were good but then it started being retarded again :[
guntip 1.4
and i have been messing with the psi and gun settings also.
i'm ditching school trying to finish this up!
Old Mar 18, 2008 | 05:27 PM
powerflow's Avatar
Default Re: (kelviiv)
Does the gun sound like its spraying even, no slight spurting? Have you been testing the spray pattern on some masking paper or something? Keep in mind the base / clear will have very minimal peel at best, unless its a flat panel and you can apply on the heavy side. Base does have a slightly more rough feel compared to hardened clear that's flowed out. Have you sprayed Omni in the past or used the same equipment before?
Modified by powerflow at 6:46 PM 3/18/2008
Old Mar 18, 2008 | 05:48 PM
kelviiv's Avatar
this is my first time
Old Mar 18, 2008 | 06:04 PM
powerflow's Avatar
Do you have enough paint to test out different gun control styles? Any junk fenders or something to test out on? Try holding the gun closer, backing off the pressure so its not too high at the cap, bump up the material, be prepared to move a little faster. I paint with a gun distance closer than average, overlap perfect 50-60%, material near or around max range (not all base colors), and I move quicker. But not everyone paints the same.
Old Mar 18, 2008 | 06:28 PM
kelviiv's Avatar
yeh i do have enough paint to test out gun control
ill try it again tomorrow
oversteer_ms
Paint and Body
10
Nov 7, 2012 10:39 AM
xbabysharkx
Paint and Body
Sep 9, 2008 09:16 PM
SneezinCD5
Aug 17, 2007 06:57 AM
D16SiHatch
Paint and Body
Jul 16, 2007 10:07 AM
joblow
Mar 15, 2003 07:28 AM
