Seam sealer
Old 11-30-2011, 09:11 AM
jksmith's Avatar
Default Seam sealer
Working on the bay in my car and was about to grind out all the pounds and pounds of seam sealer Honda puts in there. Just wanted to know what I need to do after i get it all grinded/sanded out is?
Old 11-30-2011, 11:23 AM
Hawkze_2.3's Avatar
Default Re: Seam sealer
What do you want to do? Put in new seam sealer? Prime the bare metal? Use filler to smooth the joints? etc etc.....
Old 11-30-2011, 11:39 AM
jksmith's Avatar
i just want to smooth the seams out, and was wondering if i needed to put sealer back over what i ground out or can i just body fill it and smooth it out, then sand prime it?
Old 11-30-2011, 12:06 PM
Hawkze_2.3's Avatar
Body filler can go on bare metal, so you could do that. You should also be able to find sandable seam sealer....so either way, haha
Old 11-30-2011, 12:13 PM
jksmith's Avatar
so nothing structurally will be at risk with grinding out all the seam sealer ?
Old 11-30-2011, 12:42 PM
Hawkze_2.3's Avatar
No, the seam sealer is just there to prevent leaks and rust. Spot welds take care of the structural part.
Old 12-01-2011, 04:06 AM
jdmcx's Avatar
thought that the should be someting over the seams so if you gind it all of you should put something to protect it.
Old 12-01-2011, 12:03 PM
jasoncrashtech's Avatar
if you take out all seam sealer, and spread body filler in the seam the body fill will crack. moisture finds its way though.
flexing will also be there as well, seam sealer is a better choice.
amrussellusn
Paint and Body
10-07-2012 03:13 PM
evilclown312
Paint and Body
06-27-2012 12:06 PM
fleabag
Paint and Body
17
08-29-2010 08:02 AM
VTECth1s
Paint and Body
05-17-2007 09:01 AM
GroundZer0 336
08-13-2003 01:12 AM
Quick Reply: Seam sealer
