Paint Problem
Old Feb 2, 2011 | 11:18 PM
gpibambam's Avatar
Default Paint Problem
Hey-
I have an civic that has lost some of its clear coat and is starting to lose paint in some small spots. Can I pick up a can of paint from the dealer, sand it down and repaint myself?
Old Feb 3, 2011 | 06:57 AM
eksessiv's Avatar
Default Re: Paint Problem
I'm not 100% sure I am correct, but if you can get the color code it might be cheaper to get it from a company that is not a dealership.
Old Feb 3, 2011 | 07:54 AM
FEVERONER's Avatar
To be honest if you spray it yourself no matter if you get the same color code it never comes out the same unless you spay the whole car....
Old Feb 3, 2011 | 07:58 AM
eksessiv's Avatar
True true.
Old Feb 5, 2011 | 02:37 PM
prelude1897's Avatar
Fixing that one spot isn't going to have it look the same as the whole car, so I'd either reshoot the whole car, or you can go to www.paintscratch.com and get the color made rather than going to the stealership
Old Feb 10, 2011 | 07:45 PM
tegra1027's Avatar
From what it sounds like, the clear is fading off and now the color is fading off as well. If thats the case, you need to feather out the peeling paint, spray at least the panel with color and then reclear. You only need to put color where the old color was coming off or where you sanded through. Blend it out to the edges of the panel and clear the whole thing. If you want to make the color match better, if nbecessary blend the color onto the adjacent panel and clear that one too.
yong321
Paint and Body
Feb 5, 2019 09:21 AM
ennohohbee
Paint and Body
Jan 7, 2014 09:19 AM
moparmusclecars
Honda Insight & CR-Z Hybrid
Feb 20, 2012 04:22 PM
messeduprex
Paint and Body
Jan 8, 2009 07:33 PM
