Paint help
Old Oct 25, 2013 | 07:22 PM
MANualBoy's Avatar
Default Paint help
Well this is on my paint job, it is black spray paint overspray that got wiped and turned into this ****, anyone ever dealt with this? Any tips?
Well cheers and thanks for the read!
Old Oct 25, 2013 | 07:25 PM
TypeRfit's Avatar
RESIDENT
Default Re: Paint help
https://honda-tech.com/forums/showth...3164041&page=8
^^Bring that same question with some better pictures into this thread, we'll be glad to help you^^
Old Oct 25, 2013 | 07:26 PM
MANualBoy's Avatar
alright thank you!!
Old Oct 25, 2013 | 07:52 PM
barzano724's Avatar
Have you tried using pre cleano its a cleaner for prepping the area for paint now if you use it might take it off then you just wax it to bring shine back or you could try a clay bar which removes this kind of stuff on paint
Old Oct 25, 2013 | 08:02 PM
jbpnoman's Avatar
Attack it with a clay bar.
Old Oct 25, 2013 | 08:05 PM
MANualBoy's Avatar
alright I will try your suggestions thank you guys!
Old Oct 25, 2013 | 08:57 PM
crazyhouse2011's Avatar
Buy a rattlecan of your car's paint code and recover that.
Old Oct 25, 2013 | 09:09 PM
MANualBoy's Avatar
thanks for the advice!
Old Oct 27, 2013 | 06:37 PM
AutoBodyByJake's Avatar
Do not spray over it to cover it up. That's horrible advice. If its a factory finish you can take laquor thinner, put it on a rag and rub it off. Or rub it down with a wet clay bar. Or buff it with heavy cut compound. Any of these will work. Start with a clay bar. That's your best option.
Old Oct 27, 2013 | 06:40 PM
TypeRfit's Avatar
RESIDENT
I noticed your fairly new, check out this thread. Trying to get the paint maintenance/correction knowledge out there. Also trying to learn some different tips from others.
Old Oct 29, 2013 | 08:56 AM
stancedef89's Avatar
If you're car has enough clear coat on it you can wet sand it with 1500 or 2000 then with a 3000 soft pad and a 5000 soft pad. Depending on whether your car is a single stage or base-clear paint job you should have enough to cut it down to get the over spray off and then rebuff it. This would be the correct way to do it being so that I do it everyday at work.
Old Oct 29, 2013 | 07:58 PM
Hidenplanvew's Avatar
I would start with clay bar... Cutting and buffing should be your last resort
Old Oct 30, 2013 | 05:47 PM
/\ agreed
Old Nov 4, 2013 | 12:17 PM
The_Nightrida's Avatar
CLAY BAR... thats where its at, **** does wonders with overspray.
aznlangjai
Paint and Body
Aug 8, 2015 06:04 AM
CblP s40
Detailing
13
Dec 13, 2010 01:39 PM
iperez
Dec 7, 2003 04:39 PM
philibuster
Sep 24, 2003 09:28 AM
speedaccordinly
Sep 8, 2003 01:28 PM
