Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Honda: How to paint your engine cover
Step by step instructions for do-it-yourself repairs.
Official: Post Your Valve Cover (56k warning)
#7829
Re: Official: Post Your Valve Cover (56k warning)
Couple of pics of mine all primered up and ready for paint. all shaved now and will have the writting polished once painted.
#7830
I used the same color and it came out exactly like yours, I used the Medal Cast Ground Coat and did everything like you are suppose to and it came out more of a red ish purple and I wanted it to be more of a blue ish purple.
#7831
That looks fantastic, and will look even better once painted. What did you use to fill it in?
Also, here's my early stage B20 cover project.
And here's a better picture somewhat of my first cover that I ever did.
Dupli-Color high temp white and clear, and used metal etching primer.
#7832
I've done a couple valve covers on here, like the chameleon paint on, and the midori green valve cover, this was a redo on the midori one. hope you guys like it.
#7834
#7835
#7836
[QUOTE=Boosted_90Teg;39399743]That looks fantastic, and will look even better once painted. What did you use to fill it in?QUOTE]
Thanks I Just used bog haha. A few people think it wont work and will get too hot and crack but others think it will work fine. Nobody had actually done it before so I thought I would give it a go and find out if it will hold up.
#7837
is this sanded down to bare metal with clear on top of that? it's a cool idea, but what was the last sand paper you sanded with? you can see a lot of the sand marks...maybe going a higher grit would make it look smoother
#7838
yeah staging down with sand papers and finishing with a rubbing/polishing compound with power ball or something would bring about a flawless shine but personally I like the cuts. the "brushed" look is ill.
#7839
#7841
u do it with sandpaper, from 600 to 800 to 1000 to 1200 to 1600 to 2000, and take really really long on each paper.
