Noob Needs Help Primering
Old Aug 6, 2007 | 01:24 PM
Peruviann's Avatar
Default Noob Needs Help Primering
i had my integra stolen and somewhat stripped so i got new front and rear bumpers but there white and my car is thunder grey and i wanted to just get them primered grey or dark black
how would i go about this ive never done anything like this before
what kinda sand paper do i need ??
what do i need ??
i searched and didnt find anything
Thank You in Advance
Old Aug 6, 2007 | 01:48 PM
Peruviann's Avatar
Default Re: Noob Needs Help Primering (Peruviann)
anyone ??
Old Aug 6, 2007 | 02:08 PM
Peruviann's Avatar
Old Aug 6, 2007 | 07:32 PM
Peruviann's Avatar
can anyone help ?
Old Aug 6, 2007 | 08:29 PM
Tranceaddict87's Avatar
i'm just a fellow noob in the world of body work and such but this might be of some aid to you.
http://www.team-integra.net/se...D=855
Old Aug 6, 2007 | 10:44 PM
Son2BEHO's Avatar
if the paints still good on that part you want to primer you can just scuff it with a scotchbright pad like they sell in auto paint stores...you want to scuff it till its the finish is dull
Old Aug 8, 2007 | 12:41 AM
IP RACING's Avatar
Default Re: Noob Needs Help Primering (Son2BEHO)
if your going to shoot primer.
sand them with 320 or 400 and then shoot primer on that.
but if there white. and the paint is alright. Id say just grey scotch brite them and just shoot paint right over that
Old Aug 8, 2007 | 04:54 AM
VTEC_PRODUCTION's Avatar
Default Re: Noob Needs Help Primering (IP RACING)
take your bumpers, set them on some saw horses, sand them with 220, wash and use wax and grease remover, tack cloth it, and shoot primer, sand primer if you plan on painting on top of it. this is the RIGHT way to do it.
Old Aug 8, 2007 | 05:14 AM
WihaSi's Avatar
Default Re: Noob Needs Help Primering (VTEC_PRODUCTION)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">take your bumpers, set them on some saw horses, sand them with 220, wash and use wax and grease remover, tack cloth it, and shoot primer, sand primer if you plan on painting on top of it. this is the RIGHT way to do it.</TD></TR></TABLE>
I personally wouldn't use anything lower than 320 grit. If you are planning on just primering them, DA the bumpers with 320 grit, and then shoot them with a primer sealer.
Old Aug 8, 2007 | 05:17 AM
Default Re: Noob Needs Help Primering (WihaSi)
220 is fine, do it with a wetsand not a DA. a DA works way too fast and its easy to make mistakes. Ive been painting and doing body work for about 5 years and i found this to be the best way.
Old Aug 8, 2007 | 01:30 PM
IP RACING's Avatar
ive never used to 220 on bumpers. 320 or 400 only. why do you tack cloth it. I just clean it and shoot primer right on it.
Old Aug 9, 2007 | 05:32 AM
on original paint you use 220 to get anything that may be in the original paint, or any serious imperfections, there is always grime in the clear so its best to use that low of a grit and you dont have to take all day with 220...and i tack cloth it just to insure a clean surface. cleanliness is HUGE when spraying expensive paint and wanting a show finish. its just the right way to do things. you can do it that way or half *** it. its up to you.
Old Aug 9, 2007 | 07:38 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">on original paint you use 220 to get anything that may be in the original paint, or any serious imperfections, there is always grime in the clear so its best to use that low of a grit and you dont have to take all day with 220...and i tack cloth it just to insure a clean surface. cleanliness is HUGE when spraying expensive paint and wanting a show finish. its just the right way to do things. you can do it that way or half *** it. its up to you.</TD></TR></TABLE>
Hells yes, you've got to use a tack rag, before you primer, and after every coat of base.
Old Aug 9, 2007 | 12:36 PM
2.3AccordSOHC's Avatar
What would happen if you used clear coating after you primer ? Would it take away the grainy look ?
Old Aug 9, 2007 | 12:41 PM
WihaSi's Avatar
Default Re: Noob Needs Help Primering (2.3AccordSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.3AccordSOHC &raquo;</TD></TR><TR><TD CLASS="quote">What would happen if you used clear coating after you primer ? Would it take away the grainy look ?</TD></TR></TABLE>
Why in the world would you want to clear primer?
Old Aug 10, 2007 | 10:06 AM
IP RACING's Avatar
weird I dont know any painters that tack cloth before they primer. they as well AS i just clean the area with cleaner. then when about to shoot air everything off real quick and then shoot primer
mykulangot92
Paint and Body
May 20, 2010 11:04 AM
pjr710
Paint and Body
Jul 1, 2009 11:55 PM
p3terson17
Mar 24, 2007 03:29 PM
Del Campo92
Feb 28, 2006 11:34 PM
